Damaged screw head
Hi.  I picked up a fossil watch for a couple of pounds that hopefully only needs a battery, but one of the screws on the back is almost rounded off and doesn’t want to budge.  What’s the best way to deal with this?  The case is plastic so the screw is not rusted in.  I’ve resisted the temptation to put any sort of lubricant on it until I know what I’m doing.  Spa you suggestions would be gratefully received.  Thanks,  Al.
Hi  If the screw head is accesible try to cut a groouve in it with a fine knife edge  file to ceate a slot. Its not beyond some people to glue in a duff screw.  With a plastic case be very careful what you use to loosen the screw.  Be assured some body on the forum has had the same problem and will know of the way to proceed. good luck
Thank you for the reply.  Its a bit of an odd solution, but I wonder if anyone has tried solder to build up the screw or even soldering a screwdriver to the screw to gain grip.  I’ve got a colleague who can solder joints that I can barely see, so if it’s worth trying, I know just the man to ask.  Good idea, or not?
Hi  trying to solder a screw which is encased in plastic is frought with danger as the heat from the iron would cause the plastic to melt and worst case ruin the watch  proceed with extreeme caution if you follow that route. Another possible is to use a dremel and drill the screwhead off leaving a small stub to be removed with pliers
Thanks again for the replies.  I’d arrived at the “drill it out” solution but I’m still reluctant in case I can’t get the stub out.  I suppose, worse case it may end up with 3 screws holding the back on which isn’t the end of the world.  I hope it only needs a battery. Cheers.
Being plastic it shouldn't be overly tight. You can try using a flat blade driver with a sharp edge to help provide the grip on the edges as you loosen.
If it won't budge at all then carefully and slowly grind the had with a dremel. This will leave a stub protruding once the back is removed which should come out easily.
In assuming you've loosened the other screws and confirmed it is screwed down and they're not moulded in cosmetic heads?
This often happens with fashion watches and they're a pop off case back.
13 minutes ago, mlfloyd1 said:
By some screw extractors from Esslinger.
A screw extractor may work (assuming it's a real screw) but is kind of pricey for an one-off job on a doubtful watch..
BTW Esslinger is an US seller.. I gather the OP is in the UK.
    • I have it, so until we get a lunch one day , nearly everyday is with my mum at the moment.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
