Clock cleaner
watchweasol
A Finnish watchmaker I know gave me the recipe they used in school, I've used it for some time and am very happy with it. It's gentle and fairly nontoxic (don't drink it of course, but it doesn't contain harsh solvents).
1L 99% isopropyl alcohol
3L distilled water
50g oxalic acid
60g oleic acid
around 80 grams of 24% ammonia
In a stainless pot, heat the alcohol and 1L water, add the oxalic acid (powder) and dissolve, add the rest of the water and oleic acid, then add ammonia slowly. It will go cloudy, then turn clear. The ammonia is reacting with the oleic acid making a soap, when it goes clear all the oleic has reacted. This keeps the solution fairly safe for brass, as the ammonia now being a soap doesn't eat the metal like some other cleaners with higher ammonia concentrations.
Rinse in hot water, with a final bath in alcohol before drying with hot air. I have never had a part rust with this, but the final alcohol rinse is important.
I'll add- the oxalic acid is a mild rust remover. You might find it advertised for removing rust stains. And this solution won't magically clean a filthy movement. Some time with a small stiff brush and lighter fluid getting the gunk off prior and pegging holes after (and/or before) is still required. And as mild as it is, it can still eat certain lacquers. On a laquered piece I usually just hand clean with soap and brushes and water. Alcohol to absorb to water, dry in hot air, then check and peg all pivot holes. You only have to assemble one clock without pegging and see black gunk flow out when you oil to know pegging is actually a time saver.
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
