Omeaga Seamaster Clasp
First of all, thanks to everyone who promptly replied to my dial dot issues last week. I think I got it sorted. I just took in a stainless Omega. The clasp will not close and the buttons are not moving freely. I put the bugger in the ultrasonic for about an hour and then added Mobeus oil around both buttons. It is a bit better but the clasp is still not closing as it should.
Does something need replaced or is there a possible adjustment ?
There is a spring inside (obviously) which gets fatigued and this is not sold separately as far as I am aware.
I have always just replaced the clasp for clients in the past, cousins sell them but not cheap.
If you are handy with spring wire you may be able to make one by opening it up and forming it to the same pattern as the old. I have never done this as I worry about clients loosing their watch so would rather just buy a new clasp, but then, I am neurotic!
    • So here is the new base, I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded. The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool. Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder v2.pdf Modular Movement Holder v2.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
