  • Similar Content
    • By agregate
      I'm trying to release the tension in the mainspring on an Elgin grade 144 pocket watch and unlike my grade 291, this one has a hidden click and the main barrel is tucked underneath a plate.
      I've looked online and found a single forum post stating I need to push a pin or very small object into a hole underneath the main barrel (which there is one) while simultaneously holding the stem in place to stop it from unwinding all at once.
      The problem is, I've got a single screwdriver that fits in this pinhole and after poking around in a few directions, it doesn't seem to be releasing the click. I don't know if this is the right hole (it is the only one) that I'm putting it in, if it's supposed to be on a specific angle at insertion, a certain depth, etc. I've attached photos of the side of the movement and a diagram of what I am doing.
      For what its worth, its a lever set.
    • By Misshollypocket
      I actually have a couple problems I could use some help with. I’ll start with the more serious one I guess. I don’t have any trouble getting the back off my watches or changing the battery, but every time I use my tool to snap the back back on, something happens to the crown pin. It just lets go and comes out. I thought it was a strange occurrence the first time but I tried another one this week and got the same results. I’ve done this same thing on hundreds of other watches of different types and brands but never ran into this problem before. Can someone please help me figure out what I’m doing wrong?
      Also, a couple of my watches don’t seem to be able to adjust to my teeny tiny wrist size. In my Monarch, the majority of the links don’t have holes to remove the pins. Is there any other way to remove a couple links. Any advice would be appreciated immensely!!!
    • By JJM
      Is this a rubber 'O' ring in here?
      Not too sure how to approach replacing this....
      Or do I just hit it with my chequebook?
    • By Trevelyan
      Hi, new to repairing, just getting my feet wet, so be prepared for me to use incorrect language, and have things explained like I'm 5 :)
      A couple years ago, I purchased a Seiko Sportsmatic Weekdater, cal. 6619-7050.
      Soon after purchase, the crown detached from the stem, and I took it in to local watchmaker for repair. It was returned in apparently good shape, but actually the problem still exists.
      I'd like to learn how to fix the problem, and hopefully bring this watch back to my wrist.
      It appears that the crown screws onto the stem, but that is as far as I have got.
      Any assistance would be welcomed. I did find a service manual elsewhere, but I'm a bit lost as it's my first.
      Seiko Sportmatic 6619A.pdf
    • By rduckwor
      A vintage Elgin 15/0, Gr 559.  I took it down, cleaned and lubricated it and it is gaining 15 minutes/24 hours.  I have looked at the HS, it appears to be perfect, clean, flat, not magnetized (de-magged the movement X 3 already), and in position between the regulator pins.  Not hung on the center wheel.  Correct mainspring, and balance is not knocking.    I do not remember amplitude, but IIRC, it was above 22 which is O.K. by me with the movement.  Please give me some ideas as to how to correct this.  It doesn't seem like there are enough timing washers in the world to slow this down!
      Thanks,
      RMD
