Seiko 6217A
Cheers Mates!
I have problems with that "setting lever w/wheel" doesnt manage to drive the canon pinion and minut wheel. Its keeps jumping uo and down while I rotate the stem, but If I take it towards the clock it manage to drive both wheels. Both the clutch wheel and minut wheel looks ok. I tried another canon pinion that are looser, then it was no problem, but then the canon pinon unscrew it self out of the grip of the minut wheel. Somebody having the same issues??
9 minutes ago, arkobugg said:
The clutch wheel looks good with pointed teeth,  but of course I dont have any new to compare with..The date corrector is new..
Strange. And the setting lever is turned the right way up? Can't see on the picture.
When I look at the day corrector or the setting lever with wheel, it looks like its climbing on the minute wheel while its griping into this and it sort of trying to get to the right sort of..  I have to take it a part again..
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
