Seiko 6217A
Cheers Mates!
I have problems with that "setting lever w/wheel" doesnt manage to drive the canon pinion and minut wheel. Its keeps jumping uo and down while I rotate the stem, but If I take it towards the clock it manage to drive both wheels. Both the clutch wheel and minut wheel looks ok. I tried another canon pinion that are looser, then it was no problem, but then the canon pinon unscrew it self out of the grip of the minut wheel. Somebody having the same issues??
9 minutes ago, arkobugg said:
The clutch wheel looks good with pointed teeth,  but of course I dont have any new to compare with..The date corrector is new..
Strange. And the setting lever is turned the right way up? Can't see on the picture.
When I look at the day corrector or the setting lever with wheel, it looks like its climbing on the minute wheel while its griping into this and it sort of trying to get to the right sort of..  I have to take it a part again..
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
