Rotor Removal
Could someone please give me some guidance on how to remove the rotor from this ETA 2892-2  movement. I dont want to go in heavy handed as these gilt movement damage easily. Many thanks.  Chris...
I'm not familiar with the movement, but my guess would be that there's a (isn't that) special tool that has three posts to fit in the three holes at the top of the rotor. You probably hold the rotor and loosen the hold-down disc. Just a WAG, and probably what you are hoping against. Good luck.
To remove the beaing you need a special tool but just to remove the rotor you just take of the three screws holding the automatic mechanism, turn it around and unscrew three small screws on the underside and the rotor gets loose..
Could take a couple of shots for you if you wish..
Thanks all but the price of the Horotec tool is a bit prohibitive... I have managed to free it with a very sharp piece of peg wood in one of the cut outs and push it round..The bearing is OK its just that the balance needs some work and you cant remove it with the rotor in place.
You really should've inquired about that before you went ahead and undid that bearing. As I'm sure you'll find out soon if you didn't need that expensive tool before you'll need it now. Basically impossible to remount the bearing without it.
I've not taken the bearing out of the rotor because it seems to be ok...A more pressing problem is that now Ive taken the balance out there seems to be no power arriving at the escapement despite winding...
Did you not remove the ring with the cutouts by pushing on the cutouts and rotating it?
Thought I had a 2892-2 lying around but the 2892A2 is almost the same just slighly upgraded.
So to avoid confusion I've taken some pictures to show how to reach the balance and where to remove the three small screws to remove the rotor.
Picture 1 and 2 shows the three screws which to remove so the winding mechanism can be removed.
On picture 3 you can see the three small screws to be removed if you want to take off the rotor without removing the bearing.
Picture 4 reveals the balance, it will only swing with the stem in position 1. Fully pushed in.
Picture 5 is how i guess you check the power transfer from the drivetrain, you have to wiggle the pallet fork otherwise nothing will happen.
If you gently wiggle the pallet fork and nothing happens you have an fault somewhere in the drivetrain.
I did that very carefully so as not to scratch the rotor. The rotor removed (bearing still on the movement) so I could work on the balance but when I got to that stage as HSL says very lethargic movement from the pallet fork. So its a tear down job
57 minutes ago, watchweasol said:
Hi Chris   find enclosed tech sheet might be of some use . Lack of power at the escapement look back in the train for a jam (dirt) broken or bent pivots mainspring broke there are many reasons but it sounds like a tear down job  good luck
Its a tear down job watchweasel...Thats the easy bit Re assembly is not quite so simple.
Thanks a lot for the PDF which is most helpful
Thanks HSL for your pics..I tried to short cut the work by removing the rotor whilst leaving the bearing on the movement but the lack of power to the pallet fork indicates something more sinister.
Chris
That's what I was saying. That ring holds the bearing to the rotor. Try putting that ring back. I think you'll find it very difficult.
Well I won't try until I've sorted all the other problems out. If its too difficult I might try making a tool or perhaps purchasing the chinese version. Thanks for your assistance .
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
