Making the micro regulator adjustments
I would like to hear the various techniques for making the fine regulator lever adjustments and beat adjustment, when available on the upper side of the balance bridge.
If you get within 0.8ms in beat, what are you doing to get it tweaked to 0.1 to -0.1 ?  I use a double loupe magnification on my reader glasses and sometimes seem to go too much one way and then again too much in the other direction when fiddling with this.
Thanks,
George
Most likely, most of us are like yourself, it's like a dance.
I try to brace my hand and use a twisting motion with the tool rather than a push to move in very tiny increments.
Also I recommend restarting the timegrapher after an adjustment and allowing a few seconds for the amplitude to settle.
Great thought.
To prevent any marks from a tool such as a metal screwdriver, I could fashion a plastic pixie stick or a piece of peg-wood to a flat end and give that a slight twist for control. Thanks
10 hours ago, m1ks said:
...Also I recommend restarting the timegrapher after an adjustment...
Why do you recommend restarting it? I'm going to buy a timegrapher, and I was thinking in a weishi 1900 instead of the 1000, just because I've read that the dot lines in the graphic are dual color, helping in setting the beat error as you will notice if you've gone too far in the adjustment. But if restarting is a recommendation then I don't see any advantage against model 1000.
Edited by aac58
My reason for restarting:
I am using the 1000 model and after attempting to adjust beat error, with a +-3 s/day watch as an example, I may be trying to adjust beat where the graph will have one line on the top edge of the display and the other on the bottom.  I can stop/start the machine and get the graph back in the middle of the display for better reading.
Apologies for not clarifying re the timegrapher but first, I should also have mentioned, I use a piece of pegwood, (one end a point, the other a flat edge like a screwdriver) to adjust the regulating arm, for the aforementioned potential problem of leaving marks.
Restarting isn't necessary at all, just that it seems to take longer to pick up the difference if left running than if you press stop then strart, I haven't timed it, it just seems that way to me, but either way, you'll need to allow a few seconds for the beat to settle back into a smooth rhythm.
The dual coloured lines are useful, and even restarting will still work, you just note whether the blue or the yellow line was uppermost. I find it useful because if you go from a small BE like 0.5 to 0.3, you could 0.3 on the opposite side and the lines are so close you can't tell on the screen so the split colour helps.
Instead of pushing on the regulator, try little sideways taps. Here a screwdriver works better than pegwood. Little taps, not hard knocks. This works for me when chasing the last few ms.
Good luck.
Anilv
Good advice!
Problem is the higher sticking friction against lower sliding friction. The force needed to break the regulator arm free is higher than the force needed to move on the sliding arm. Pushing, you cannot avoid to push too far.
I made a tool (slotted brass rod with a big radio button on the upper end) for better feeling:  the mentioned problem gets a bit smaller but is still there.
Now I mainly use a screwdriver with brass blade and tap with the back of my tweezers.
Thus you always apply a limited amount of energy and overshoot can be avoided.
Frank
Another idea that may work, when the regulator arm extends over the cock-plate, would be to have a brass screwdriver blade size 60 or 80, and place the edge just under the side of the regulator arm and pry the arm in the direction desired by raising the screwdriver handle up in a leveraging method.
I don't have a watch currently to show an image of but I've put this image together.
micro_regulation.png?raw=1
Edited by GeorgeC
edit image text explanation
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
