waltham hands
anybody know where i can obtain blue or black hands for a waltham pocket watch 1.90 x 1.18 at a reasonable price.tried Cousins but they dont seem to have this size and although there seems to be plenty on E-bay they are mostly from the USA with ridiculous postage charges.thanks B.
sorry to tell you but you cant buy these hands from suppliers. Ebay is the way to go but try searching based on movement size instead of hole size you will get more results. plus shipping should not be too much since most sellers participate in the global shipping program which allows you to ship an item to any country outside the US for the same cost as within. The items gets shipped to an exchange center in Kentucky where they ship the item to the destination country, its great because the exchange gives you a separate tracking number once it leaves their warehouse, and the shipping time is pretty much the same. I however may have some hands, i can list them on ebay for only the postage charge and this way ill ship using the GSP, which probably be like $7. what is the size of the movement? If i dont have them i can send a link to some ebay listings
not sure but is a traveler and i believe a 16s.the dial is 42-43mm.
That should be either a model 1908 or 1899. There are few differences between them, and I'd guess that the hands are the same. Very common movement. I believe the Traveler, mostly a gilt finished movement, was made for export, with most being sold in Britain. Good luck.
I just thought of the fact that I may have seen "Traveler" marked on 1888 models as well. And I just verified this in "The Complete Guide to Pocket Watches".  If yours is an '88 model, I hope you have a case for it. Like the '72 model Waltham, they take a special case.
If you can provide an image, or at least the serial number, from the movement, the model can be determined. Cheers.
Edited by MrRoundel
yes get the serial number and look it up on pocketwatchdatabase.com. its not always accurate but it will let you know the model, size, and will show images of the movement and cases as well. i have the official waltham pocket watch ID and price guide from 1976, which is 100% accurate. so get that serial # and post it
Edited by saswatch88
Yes looked it up. It's a 1908 movement
8 minutes ago, saswatch88 said:
Thanks. Will give it a go. B
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes.
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
