Hermle 130-627
Mattaphysics
I got this Elgin clock with the floating balance and i love it. The problem I'm having is the balance is only rotating maybe 90° and the chime is muffled. I've tried adjusting it it seems like it needs more than an adjustment. And I'm unsure why the chime is so weak. I thought maybe it was because the hammers were resting on the rods but i bent them a little and that didn't work all that well. It chimed a bit louder but not that much. Any suggestions?b137cea681cd445abd4a61e7d18c42cd.jpg
Sent from my LM-X210CM using Tapatalk
From what I can see it looks very dry I don’t see any oil. Have you let the springs down and checked for wear. Not the best of metal in these, its quite soft compared to movement long ago. With the floating balance, make sure it is clean at the ends, normally jewelled at each end. A drop of watch oil in the jewels, then work the balance up and down a few time, the balance must be free. Clock oil on all moving parts this includes the pallet pins and escape wheel teeth. If the clock is cleaned and the springs, I think you will see a big change in the action of the chimes and balance.
 Hi  Check the gong hammer assembly is free,  lift each individual hammer and check that it drops smartly not in slow motion,  It they are sticky dfismantle and free off.    Remove the floating balance unit and clean in Alchohol or the like,  There is a good explanation on the floating balance on the net by Howard Millar.   I will have a look in the Hermle Manual regarding your mode.  l do like Hermle clocks very well made.  Then Proceed as explained by Old Hippy,  sound advise as always.
Ok, so I've finally got what i needed to clean this bugger. So how do i get to the dial? I'm utterly confused. The glass have any way of sliding or opening on any way i can see. There doesn't seem to be a way to get to it from the back unless you can tell? e16bc7db3a16b23d27ea0f7f31c04b3f.jpg4842b959ba09da2e87a6694805eb95a8.jpge4393b24027e07070bb4146ddf042f72.jpg1574dc39af73a506e5ab79a3579c173d.jpg94a2b4b895b07561c7862a170e4750f3.jpg
Remove the hands and all the screws from the brackets in the back and the movement should just come out.
There's a piece of glass in the front on the other side of the hands. It moves but not far enough one way or the other to get it out. There's nothing that looks like one piece will move, i removed the chime rod to see if it hides anything but no. I cannot for the life of me figure this out.
Hi  I think Old Hippy is right.  Its what is called a bracket clock as they used to stand on ornate wall brackets.  The top looks solid so the only other way in is from the bottom. The bun feet should unscrew and probably expose the fixing screws for the bottom.    :pulling-hair-out:good luck
Ok so i saw there were screws on the bottom near the feet and I kind of thought they were useless until I removed them and the bottom fell off. Than you gents so much. I'm cleaning out as we speak. So i only oil tyre jewel hole of the floating balance with watch oil right? Then use watch oil on the pallets and escape wheel?
Ok. Now I'm all set but the balance seems off. Like its not aligned or something. It doesn't swing free but is caught during its rotation. Again this thing has me flabbergasted. How does it need to be aligned? I've tried moving the collet to move the roller to one side then the other but it's not working.0d7fa87b9a0dc9f1bf0dee5628694ae1.jpg
Hi  Try removing all power and letting the balance rest then take note of its position like a watch it should be lying central. If it is with a small brush sweep the balance and check its rotation with no power.  alernativly remove the balance assy and check for smooth rotation, apply some power to the movement and check the action of the fork assy for a snappy action. Its a process of elimination, once setup ok they are usually very reliable. I have worked on both the Hermle and Smiths versions and only had regulation problems on one of them   There are some good descriptions on the workings of the floating balance on the net
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
