  • Similar Content
    • By rduckwor
      Stainless steel or copper/beryllium?
      Thanks,
      RMD
    • By rduckwor
      Early 60's Elgin 10K Shockmaster. I suppose one of their attempts at water proofing a watch (see the crystal and gasket in the second picture). The question is how to get the crown off (Its wobbly when pulled out to the set position and I am certain it contains a gasket) so I can remove the movement? Dis-assemble the keyless works in place so I can grab the stem and unscrew the crown?? Thanks.
    • By Lenj
      Hi all,
      Strange I have two Fema clock movements to repair, both with broken mainsprings and one with a broken click spring, can you please tell me, are the click springs readily available???has anyone bought one, if so where from?
      Photo attached of good click spring, this is the type that I need..
      Hope you are all well..
      Thx Len
    • By rduckwor
      Ideas on where to find a suitable assortment of studs?  Cousins has round and square, but Elgin uses a wedge shaped stud.  File my own?
      Thanks,
      RMD
    • By rduckwor
      Does anyone have a source for the two - ended shock springs for a 7s26 movement.  My is in the Netherlands.  Not the three lobed DiaShock , but the cheaper two-ended.  I cannot locate them on Cousins or Ofrei.  Sieko "hold spring" P# 0015703
      Thanks,
      RMD
    • Today this package from sweeden came in mail, containing 11blacd escapement wheel, donor  @rogart63 . Following fourteen years of in to do box  I will hopefuly  bring my bulova snorkel back to life and  soon, I will post a picture of it on watch of today thread. Thank you Rogart63 for this gift, very precious to me. In appreciation of your generosity and in your name, I make sure to pass on three winding stems to the novices and three balance staffs to experienced learners.  I have no problem shipping small parts.
    • Well on the plus side, its a whole lot more healthy than a deep fried mars bar.
    • Ran out of Cheerios
    • Ahh the healthy option, two of your five a day, orange juice and chocolate.
    • A Sekonda Classique from the same junk pile lot as the Seiko 7N32 above. Not quite as attractive, arguably, but not bad for 1/7th of the £3.20 the whole lot cost (or to put it in context, less than the cost of a Mars bar). Other than very slight pitting on the clasp, and of course a flat battery, there was nothing wrong with it. A quick polish and a fresh button cell and it joins the club.
