Anyone having experience with this glass press?
VWatchie
My experience with the handheld cheap Chinese glass presses on eBay is truly poor, and I've come to learn that I'm not alone. Yesterday I was struggling with it for over 30 minutes to fit an armoured glass in a Vostok Amphibian before giving up. At that point, while still holding it in my hand looking at it with disdain, I thought: "What a piece of utter rubbish!".
Anyway, what I'd really want would be a Robus press, but gosh, that would be over £500 with the die set (tax included, excluding shipping)! So, I found this tool "Professional spindle press for housings and glasses with twenty-four inserts" on eBay for £72. It sure sounds promising, but it would be great with a review, or if none can be had your opinion.
That is the Indian copy of an MKS 46610 (famous Japanese brand), I got one as clearance from Germany and paid maybe less than that. If you use the search function you should find my posting.
Edited by jdm
Have a Sternkreuz press i use for most glasses. Love it. I bought a second one on tradera some month ago for spares.  Also have an other which looks like a Robur but not 100% sure it's a Robur. Was thinking i could make an adapter  so i could use some other dies as the Robur ones cost a lot of money. Maybe i can part with that as i have to many presses anyway.
12 hours ago, VWatchie said:
These (Indian) presses nearly all are poorly bored: axis of upper and lower die are neither same nor parallel. That makes problems like you had.
Better go for used pro presses as advised before.
Frank
You really cannot skimp on a watch fitting glass tool. You need to have one that you can trust and get the repair done without worrying about is it going to work. The cheap tools will not do a good job, they do not fit properly, and they break, not lined up and will not last long. Buy the best and it will last a lifetime. I had many including the Robur. It is necessary have tool.
I have no problems with mine. you had one or are you speaking with the usual prejudice about Asian tools?
Another type I recommend is the Aluminum one withe the screw in between pillars.
No need to spend big money or go hunting vintage when it comes to decent tools.
If money wasn't an issue, I'd go for a high-quality press. As oldhippy says: "Buy the best and it will last a lifetime". Not only that, over time high-quality tools are the most inexpensive as you never have to replace them. Being a hobbyist though I have no idea how many crystals I'll be needing to replace. It is a predicament, and as per usual I really don't want to wait until that perfect used tool becomes available for auction, and then I might still lose the bidding.
Haven't really made up my mind, but I'm leaning towards giving the press I linked to a chance. The seller has a 100 % reputation and the description says: "Heavy and precise spindle press for safe pressing in of glasses, for careful positioning of steady rests and for safe closing of pressed housing bottoms. Extremely precise work due to finest spindle actuation.The seller also claims: "Proven Ernst Westphal Premium Quality - we only supply with products which meet our high standards as a traditional German wholesale specialist for fine watchmaking and jewelry supply for more than one hundred and twenty years." Plus covered by the "eBay Money Back Guarantee".
It would have been interesting to read the post @jdmwas referring to but (as usual) I'm unable to find it...
Edited by VWatchie
That's a valid and interesting question and I'd like to know as well. Being a Swed and consequently naive (as our genius prime minister put it a few years ago) I just assumed there was personal experience behind the statement, so yes, let's make sure!
It's a pinned topic, all the most used tools have one. And this very thread is a great candidate to be merged there.
1 hour ago, matabog said:
I have this one and it is very nice!
If I'm not wrong it has no lever neither screw, which means some tight crystal, caseback or rotating bezel  will not go in place with the limited direct force. The dies are few and have a threaded hole, so one would have to make new ones to be use correct size or hollow ones.
As common with Chinese products it can be found cheaper elsewhere https://www.aliexpress.com/item/E25-Watch-Case-Press-Tool-High-Quality-Desk-Set-Watch-Pressing-Machine-for-watchmakers/32850805250.html
even a better price on ali
Actually it is a screw type press. Rotating the round knob (or wheel - it is about 6cm in diameter) the working piece descends, without rotating.
The tool provides a lot of control.
You need M6-hole dies, which I suppose are standard.
I used to import them from India for years and know their tools very well. There were tools that I didn't touch and tools that were ok and usable. I could examine them at the exporter's site,  the customer here has to try and error.
Frank
Edited by praezis
With the tool I'm considering buying, do you know if the die is rotating with the screw/wheel when rotated, as I've tried to illustrate in image B, or if it stands still as I've tried to illustrate in image A?
Every batch of items made in a low tech / no QC factory may come out different. The press I got has castings defects, so it was sold for a discount. Now the Chinese largely use CNC and QC had improved.
Good to know you were in tool business, still you are?
Of course it doesn't, otherwise I could not have said that it works.
However I recommend that you consider the other one posted above, which is more sophisticated and not so unnecessarily heavy. That original MKS is after all a something dating back to the 60's easily.
Frank
Thanks! Do you have any personal experience with the tool that I show in my previous post (and provided a link to in my first post)? If so your opinion would be much appreciated!
Thanks! I knew it was a "stupid" question, but I've had too many tool disappointments during the past two years (that I've been doing this) that I no longer dare to take anything for granted.
Yes, that other tool looks like a very good option, but then I would have to order dies separately. I don't really mind that, but I have much too little experience to know what to get. The ones you listed look nice, but then I can't determine if that's what I need, how I can tell if they will fit without some modification or extras, if it's just for Rolex watches, or if... and so on... You get the picture :unsure:
Anyway, if you guys can provide me with a link to a nice set of dies that will fit without modifications to the tool or the dies that will cover most common needs I'll order it without a moment's hesitation :lol:
Is not that difficult really. As Matabog noted, dies threaded M6 are standard. The nice expensive set have their Dia. specified, the Chinese write Rolex just to indicate quality, but we know that true Rolex-specific dies are for the screw-on case-backs ...that's another story.
Then on AliX search  "watchmaker dies", 20 pieces nylon are like$8, aluminium quite a bit more. I personally choose based on shipping times, things have improved but China post is still very slow, HK, NL post are OK, 7-10 days.
I have been reading the comments on this thread with interest.
I had loads of tools for removing crystals and backs of watches.
Today you only need a few, but make sure they are the best that you can buy. If not they will not work, they will break and damage the crystals. You need tools that you can trust. For removing backs, the last photo.
Correct, I'm sure readers can appreciate a detailed discussion with the reasons why something is good or not.
Also I agree with your recommendation about using a  double-handed, four-points hand wrench, that can be a good alternative to a bench opener, but will require a vise and a good holder - see below.
Since these have become kind of rare, here two links for buying new
And, to demonstrate how Brand and Price do not necessarily equate to function and practically, here's something that i think is really stupid. https://www.cousinsuk.com/product/straight-double-arm-up-to-054mm-bergeon-polygonal
After speeding £150 must be deluding to learn that a 2 points hand-held will easily slip and scratch the case-back.
Common issues with all these is holding the watch tight. Forget about plastic and metal holders with round posts, the watch will always push up and leave. What really works for me is a wooden one https://www.aliexpress.com/item/32995883552.html
Edited by jdm
    • I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled uk their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
