Anyone having experience with this glass press?
VWatchie
My experience with the handheld cheap Chinese glass presses on eBay is truly poor, and I've come to learn that I'm not alone. Yesterday I was struggling with it for over 30 minutes to fit an armoured glass in a Vostok Amphibian before giving up. At that point, while still holding it in my hand looking at it with disdain, I thought: "What a piece of utter rubbish!".
Anyway, what I'd really want would be a Robus press, but gosh, that would be over £500 with the die set (tax included, excluding shipping)! So, I found this tool "Professional spindle press for housings and glasses with twenty-four inserts" on eBay for £72. It sure sounds promising, but it would be great with a review, or if none can be had your opinion.
That is the Indian copy of an MKS 46610 (famous Japanese brand), I got one as clearance from Germany and paid maybe less than that. If you use the search function you should find my posting.
Edited by jdm
Have a Sternkreuz press i use for most glasses. Love it. I bought a second one on tradera some month ago for spares.  Also have an other which looks like a Robur but not 100% sure it's a Robur. Was thinking i could make an adapter  so i could use some other dies as the Robur ones cost a lot of money. Maybe i can part with that as i have to many presses anyway.
12 hours ago, VWatchie said:
These (Indian) presses nearly all are poorly bored: axis of upper and lower die are neither same nor parallel. That makes problems like you had.
Better go for used pro presses as advised before.
Frank
You really cannot skimp on a watch fitting glass tool. You need to have one that you can trust and get the repair done without worrying about is it going to work. The cheap tools will not do a good job, they do not fit properly, and they break, not lined up and will not last long. Buy the best and it will last a lifetime. I had many including the Robur. It is necessary have tool.
I have no problems with mine. you had one or are you speaking with the usual prejudice about Asian tools?
Another type I recommend is the Aluminum one withe the screw in between pillars.
No need to spend big money or go hunting vintage when it comes to decent tools.
If money wasn't an issue, I'd go for a high-quality press. As oldhippy says: "Buy the best and it will last a lifetime". Not only that, over time high-quality tools are the most inexpensive as you never have to replace them. Being a hobbyist though I have no idea how many crystals I'll be needing to replace. It is a predicament, and as per usual I really don't want to wait until that perfect used tool becomes available for auction, and then I might still lose the bidding.
Haven't really made up my mind, but I'm leaning towards giving the press I linked to a chance. The seller has a 100 % reputation and the description says: "Heavy and precise spindle press for safe pressing in of glasses, for careful positioning of steady rests and for safe closing of pressed housing bottoms. Extremely precise work due to finest spindle actuation.The seller also claims: "Proven Ernst Westphal Premium Quality - we only supply with products which meet our high standards as a traditional German wholesale specialist for fine watchmaking and jewelry supply for more than one hundred and twenty years." Plus covered by the "eBay Money Back Guarantee".
It would have been interesting to read the post @jdmwas referring to but (as usual) I'm unable to find it...
Edited by VWatchie
That's a valid and interesting question and I'd like to know as well. Being a Swed and consequently naive (as our genius prime minister put it a few years ago) I just assumed there was personal experience behind the statement, so yes, let's make sure!
It's a pinned topic, all the most used tools have one. And this very thread is a great candidate to be merged there.
1 hour ago, matabog said:
I have this one and it is very nice!
If I'm not wrong it has no lever neither screw, which means some tight crystal, caseback or rotating bezel  will not go in place with the limited direct force. The dies are few and have a threaded hole, so one would have to make new ones to be use correct size or hollow ones.
As common with Chinese products it can be found cheaper elsewhere https://www.aliexpress.com/item/E25-Watch-Case-Press-Tool-High-Quality-Desk-Set-Watch-Pressing-Machine-for-watchmakers/32850805250.html
even a better price on ali
Actually it is a screw type press. Rotating the round knob (or wheel - it is about 6cm in diameter) the working piece descends, without rotating.
The tool provides a lot of control.
You need M6-hole dies, which I suppose are standard.
I used to import them from India for years and know their tools very well. There were tools that I didn't touch and tools that were ok and usable. I could examine them at the exporter's site,  the customer here has to try and error.
Frank
Edited by praezis
With the tool I'm considering buying, do you know if the die is rotating with the screw/wheel when rotated, as I've tried to illustrate in image B, or if it stands still as I've tried to illustrate in image A?
Every batch of items made in a low tech / no QC factory may come out different. The press I got has castings defects, so it was sold for a discount. Now the Chinese largely use CNC and QC had improved.
Good to know you were in tool business, still you are?
Of course it doesn't, otherwise I could not have said that it works.
However I recommend that you consider the other one posted above, which is more sophisticated and not so unnecessarily heavy. That original MKS is after all a something dating back to the 60's easily.
Frank
Thanks! Do you have any personal experience with the tool that I show in my previous post (and provided a link to in my first post)? If so your opinion would be much appreciated!
Thanks! I knew it was a "stupid" question, but I've had too many tool disappointments during the past two years (that I've been doing this) that I no longer dare to take anything for granted.
Yes, that other tool looks like a very good option, but then I would have to order dies separately. I don't really mind that, but I have much too little experience to know what to get. The ones you listed look nice, but then I can't determine if that's what I need, how I can tell if they will fit without some modification or extras, if it's just for Rolex watches, or if... and so on... You get the picture :unsure:
Anyway, if you guys can provide me with a link to a nice set of dies that will fit without modifications to the tool or the dies that will cover most common needs I'll order it without a moment's hesitation :lol:
Is not that difficult really. As Matabog noted, dies threaded M6 are standard. The nice expensive set have their Dia. specified, the Chinese write Rolex just to indicate quality, but we know that true Rolex-specific dies are for the screw-on case-backs ...that's another story.
Then on AliX search  "watchmaker dies", 20 pieces nylon are like$8, aluminium quite a bit more. I personally choose based on shipping times, things have improved but China post is still very slow, HK, NL post are OK, 7-10 days.
I have been reading the comments on this thread with interest.
I had loads of tools for removing crystals and backs of watches.
Today you only need a few, but make sure they are the best that you can buy. If not they will not work, they will break and damage the crystals. You need tools that you can trust. For removing backs, the last photo.
Correct, I'm sure readers can appreciate a detailed discussion with the reasons why something is good or not.
Also I agree with your recommendation about using a  double-handed, four-points hand wrench, that can be a good alternative to a bench opener, but will require a vise and a good holder - see below.
Since these have become kind of rare, here two links for buying new
And, to demonstrate how Brand and Price do not necessarily equate to function and practically, here's something that i think is really stupid. https://www.cousinsuk.com/product/straight-double-arm-up-to-054mm-bergeon-polygonal
After speeding £150 must be deluding to learn that a 2 points hand-held will easily slip and scratch the case-back.
Common issues with all these is holding the watch tight. Forget about plastic and metal holders with round posts, the watch will always push up and leave. What really works for me is a wooden one https://www.aliexpress.com/item/32995883552.html
Edited by jdm
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
