Need Help
I have a 1911 Illinois 16s pocket watch.  I do not know anything about pocket watches.  I inherited it.  I need to know what size balance staff and jewels it takes to repair it.  The serial # is 2298372.  I have purchased a 1506 NOS balance stem and hope it is the right part.  I also have ordered a pair of balance staff jewels.  I do not know what size.  They were recommended for the 16s Illinois early 1900s.  Any help you can give me with this matter would be most appreciated.  Thank you.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
