Greetings
Hello forum folks,
I've been tinkering with watches for maybe 5 years now. I'm very much a beginner but I have been practicing on cheap watches and movements that it is ok to break. I've managed to make my own watch dial from a brass sheet, including brushing, rhodium plating, printing, and creating applied markers and numerals. I've also made a "smart" watch using epoxy-based putty for the case and my electronics knowledge. I have some basic skills in metal finishing including polishing and plating.
So I've mostly worked on the non-movement aspects of watchmaking and am interested into learning about servicing movements. I live in the Milwaukee area and was thrilled to see MATC (local trade school) on lists of schools that teach watchmaking -- just to have that dashed when I contacted them and the class has been discontinued for lack of interest :( So for now, I have online and book resources to learn.
I have a mostly cheap watch collection other than a Longines that I treasure. I have a few different old timex mechanicals I got off of ebay, including 2 from JerseyMo which I saw is on this forum. I have have way more hobbies than time so I'll probably be around off and on.
Dan
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
