Magnetic or Non-Magnetic Screwdrivers and Tweezers?
trigus
Complete novice here. After watching a few of Mark's videos on Youtube (great work, by the way) it appears that some of his tools are slightly magnetized.
My question is, in general what tools to you want to be magnetized and which not? Obviously, brass tweezers are going to be non-magnetic. Also I can see the value of having at least one pair of tweezers slightly magnetized. Advice?
Anti magnetic tweezers are expensive, most people cant afford to have all their tweezers anti-magnetic.
You do not want tweezers or screwdrivers magnetized, magnetism is the bain of mechanical watches and causes all sort of issues, such as causing the coils of the hairspring to stick together making the watch run fast.
If your tweezers are not 100% anti magnetic they will eventually becomes slightly magnetic, whether that is from touching magnetized parts of watches, or just them passing through other magnetic fields.
If you work on quartz watches you will need atleast 1set of tweezers that is 100% ant-magnetic to pick up the rotor for most people a good set of brass tweezers will do.
For everything else rather than have 100% ant-magnetic tweezers having a demagnitizer is more important.
You can buy cheap ones off ebay and you will need one as its quite regular to find that a watch you are working on is slightly magnetized that you will need to demagnetize and so will your tweezers or screwdrivers after touching the watch.
Bottom line you don't want any of your tools magnetized and the only part of a watch you want to be magnetized is the rotor in quartz watches.
Magnetised tools are a real problem when working on watches especially when working on Hairsprings. I have anti-magnetic tweezers the best and safest material is brass.  Screwdrivers can become magnetised and a quick zap on my demagnetiser sorts this issue.
My advice is this. Whenever you are about to start on a new mechanical watch repair, make sure all your screwdrivers and tweezers and other tools you might use are de-magnetised. It is also good practice to de-magnetise the watch movement before attempting any repair.  It will also save you time.
  • Thanks 2
    • Hello Wai and welcome to the forum. A little information to enlighten you a little more TZIllustratedGlossary.pdf
    • I am certainly not the first one who happen to ruin the chronograph center-wheel of a Seiko 6139B. The internet, when you search for it, is littered with stories, even here on WRT there are some. One of the problems is that the service manual of the 6139A is readily available on the net, not so with the service manual of the 6139B. On top, reading other forums & stories, there are people who claim that there is hardly any difference between the 6139A and the 6139B movement, so the 6139A service manual will suffice. However, one of the crucial differences is the design of the chronograph center-wheel. Also the Seiko reference numbers are different. For the 6139A, the reference number for the chronograph center-wheel is 888610 and for the 6139B: 888611 or 888612, depending on which manual you are reading (and perhaps there is a difference between these two wheel too !??) To lubricated the 6139A chronograph center-wheel, the following graphic picture in the 6139A service manual is given; One has to press down the sprocket and oil it. Unaware of the difference in chrono center-wheel design, I pressed down on the sprocket, but there was no movement. Perhaps not understanding or interpreting the drawing correctly, I pressed with the tweezers on the 4th wheel. This caused the 4th wheel, which turned out to be a press fit to the sprocket by the 6139B, to strip off the sprocket. Thereby me joining the line of all the others, who tried this before and are now searching for "how to fix" this misfortune. In an older thread on WRT, member @ricardopalamino place a picture in which he shows the difference in center-wheel design between the 6139A and the 6139B. To the left the 6139B and to the right the 6139A. As can be seen on the left center-wheel, the 4th wheel is pressed onto a sprocket. Pressing down on it, as shown in the 6139A service manual, gives a ruinous result. People did several attempts to repair the damage, but so far, I haven't found a success story. Here is one of the attempts; Reading what has been tried already, I tried a different approach ..... but sadly failed. Nevertheless, I'll show what I've done; perhaps somebody may fine-tune or expand on the idea and has success? In my staking set was an anvil with a 4.5mm hole, exact the size needed to fit the chrono center-wheel "up-side-down". The distance between the clutch parts and the 4th wheel was 0.25mm. To support the 4th wheel as close as possible up to its center, I used feeler gauge blades, on one side a 0.25mm blade, and on the other side a combination of 0.15mm + 0.10mm blades. This allowed me to tap the sprocket back onto the 4th wheel ...... The thickness of 0.25 blades doesn't prevent some "spring" action, and so my 4th wheel was slightly deformed. The re-attachment seemed successful, but when trying to true the wheel, the connection failed again 😭 Currently there is a NOS 6139B chronograph center-wheel on eBay. Last Sunday the price was €150, on Monday the seller increased the price to €165 !!         Prevention is better than the cure and I do hope that anyone in the future, searching for a 6139 manual, with see my "Warning". As for my Seiko, I'm not going to invest €165 for one part and since the rest is pretty good, I will sell the for "parts or repair" 😞
    • Off the top of my head I can't remember which was which, but one of the hands had the clutch with the very fine radial teeth as described above, the other had a flat disc with two tiny 'pins', there was what looked like the remains of something black smeared on the opposite face, maybe the remains of rotted rubber? When I can get some good pictures of both I will post
    • If you read the NAWCC link 😀: it says, this cal. has a fine teeth clutch, no rubber. Frank
