  • Similar Content
    • By maclerche
      To the workshop, today I have received this fine old cleaning machine from Germany.
      The machine is manufactured by VEB Elektromeschanik in Glashütte.
      The machine is a type of AUII and is fully automated. It is about 30 cm. In diameter and 52 cm. high. Weight approx. 30 kilos.
      The machine is from 1979 and the gray paint is intact everywhere. In addition to the complete holder and basket on the machine, 8 other curves included. Two of them also with holder. Although DHL and Post Norden have given it a massive transport, everything is all right and it seems like it's going to be! These machines are often sold at ebay.de. It also exists in a version that is not automatic!
    • By Hammer2017
      Hi all, long time lurker, first time poster
      I've recently picked up an old Brenray cleaning machine that I want to get back in action. It's actually working perfectly - the motor spins and the heater heats up. However, it's very dirty and the paint is peeling off. I'm going to do a full clean, paint strip and repaint. I've had a look at a few of the older posts on this, so have an idea where I'm heading (I didn't want to hijack one of them!).
      My main question regards the heating plate. There is a wired heating disc sandwiched between two heating square metal plates (iron I presume) with a bolt and nuts holding the three pieces together and securing it to the floor of the machine. As I said, the plate works and heats up, but the two plates, bolt and nuts are rusted solid. I sheared the end of the bolt off while trying to get the nut holding it to the floor off. A soak in deruster/wd40, replace the bolt, clean the plates and replace is one plan (please correct me if you think this might cause problems or damage the heating plate). The other is to get a replacement Elma heating pad which, at 80mm is about the same size. My question is this - will I need to get new metal (iron?) plates to reform the sandwich, or can that new plate go in on its own?
      Also, the motor is running well, but it is filthy. What is the best way to approach this - I'm utterly ignorant here, so any tips or advice will be very much appreciated! I'll post some pics as I go along if people want to follow the process!
      Thanks for reading!
      Mark
    • By Stian
      Hi guys,
      Another question from a newbie: I have a rotating cleaning machine with three jars. In the first jar I have Sambol Platina 1:20, in the second jar Elma reinigungskonzentrat 1:9 for rinsing and in the third jar sterilized water. Thereafter the basket goes in the heater chamber.
      My issue for now is that the first jar completely foams up. The jar is 3/5 full with the solvent but becomes completely foamed up. Is this a problem with the solvent or is it not actually a problem? I got this solvent from watch-tool.de
      Stian
    • By SSTEEL
      I know Mark has one of these machines, I recently purchased one myself, and its in dire need of restoring.  I have stripped it down, and wish to rewire it and replace the ageing motor speed switch with a modern alternative, so could really do with a wiring diagram if anyone has one?
    • Does anyone know if the Agat Stop Watches, that are for sale on sites like ebay, are authentic to the USSR or are they only made to look that they are? Thankyou
    • Out of curiosity where exactly or what school was the Swiss trained watchmaker trained at? Then I'm attaching a PDF with lubrication recommendations. The your choice of lubrication's is interesting? 9010 the universal balance escapement oil but what about the gear train? You'll notice in the Omega recommendation attached file usually they recommend something lighter for the gear train 10001300 is a bit heavy.   It's really best if you would visually put the watch in beat versus wildly moving the beat corrector all over the place because it's so easy to go past where you need to be. Then if you go far enough on your machine which isn't that far it's not going to give you Incorrect results as there's a rollover air for the Graphical display and if you go far enough even the numbers so you need to be reasonably close. Then congratulations your learning? Yes you're frustrated but if I interpret correctly each watch you service is worse than when you started and you grasp that. This is why I recommended new people starting with a new watch verify the you can taken apart clean and lubricated etc. put it back and it should still function. So many times beginners start with broken watches and can't figure out why they can't fix them even with the help of the group failing to grasp the problem isn't entirely the watch a lot of times it's the watchmaker's problem. So you grasp where the problem is you're not doing something right congratulations that's an important step.     8645_WI_40_rules for lubrication cousins uk.pdf
    • That's a beauty real quality.
    • Hi  There are some which come up on Ebay  that are like a small chisel like punch on a small chisel anvil for pinching the cannon.  I have managed it with a pair of top cutters that are blunt but its too easy to over do it. If you have a staking tool you could use that with the appropriate stake and punch.
    • Just got this one. Great condition. 1942, Gold Splashed movement because of WW2. 21J Railroad grade and running strong. Thing of beauty.     Sent from my iPhone using Tapatalk Pro
