Marshall
Mainspring Winders: Full set or piece by piece?
Of all the tools needed for watchmaking the mainspring winder seems to be the biggest hurdle.
I've been poking around for a used Bergeon set (since apparently no other companies make these currently, not even from China?) but I don't fully understand what I actually need as far as sizes go. I see some are labeled as being for ETA movements, some are Rolex specific, but then there are just a bunch that seem labeled with sizes of some sort.
I could buy the handle, and the winder for the movements I'm working on now, and then just add to that as I go along. Or I could wait longer and spend more on a set of them.
I realize that getting the set is cheaper if you are buying all of them anyway, but is that what would end up happening? Do I need every one of those sizes and types of attachments? Or can I piecemeal these out over time and end up with just the ones I actually need?
Share this post
Link to post
Hi Marshall    An interesting scenario  I personally do it by hand with watches and use a home made device for clocks. Never had a problem hand winding as long as your hands are clean. With the watches as  you have found out there seems to be specifics for particular brands but I have seen some generic ones on the bay in the UK.  I think its a question of choice, how often you have the need and what is the most common one you use. its a matter of preference and associated cost.
Share this post
Link to post
Interesting, maybe I'll try that then. I guess I kind of assumed they were necessary to do it correctly but perhaps I overestimated it.
Thanks for the advice either way :)
Share this post
Link to post
Loading...
    • Welcome to the forum
    • I cleaned the hole thing, and oiled it using 9010 and hp1300. On the exit stone of the first pallet I put a drop of 9010, I've seen others using it although I now it's not the best there. I didn't oiled the second pallet. I have no photos of the timegrapher screen, and as I do not have a permanent desk I have uninstaled it. I'll take some photos next time I check the watch. But the data I gave is about what you can see there, the lines are very clean and nice in all positions except crown down, where they are quite messy. Lift angle was established at 53.0. I do not think there is any other relevant information you can see on the screen, is there?
    • Does your timing machine show a graphical display you can show us? Besides swapping escapement components what other servicing have you done to this watch? Plus what sort of lubrication are you using especially on the escapement components.
    • BLEURGH! Don't know how that ever became a "delicacy" in the Philippines!
    • We need a clear picture looking in sideways at the hairspring and balance wheel in the watch. Then yes technically her out a center but it's minimal it shouldn't be the cause of amplitude problems. They hairspring not flat would be a cause of problems especially when it's touching something. Can we get timing machine results? And that includes the graphical display with the numbers.
