Thanks GregC
yankeedog
Inspired by fellow forum member. I ordered some 4mm stictching chisels.Paired to a rough looking but good running vostok 2209 ,It is my first attempt at a stitched leather watch band..A bit rough,but so is the watch.Since it only has to fit me,simple snap fastener.
I've been toying with doing something similar. I even have the leather punches. I also thought about using a sewing machine to do the actual sewing, but I'm not sure my skills on the machine allow the level of accuracy required.
What thread did you use?
Thanks guys.I just folded the leather in half.glued together with some black automotive silicone "Gasket snot" which is water proof and flexible. I used black nylon thread with a needle borrowed from my wife's sewing basket.cutting was done with a box cutter and a metal straight edge..if you measure twice and cut once you get a nice smooth edge
Edited by yankeedog
Content
1 hour ago, watchweasol said:
Well done Yankeedog do I suspect another hobby in the offing Leathrcraft ?.  Looking good
I look at this as an adjunct hobby.Truthfully we put a lot of work into these watches.To do what? Put some chee pass Wal-Mart strap on them? Even the old vostok in the photo deserves better than that! Why not make a strap tailored to your wrist and taste? It's not hard and it befits the time piece.
15 hours ago, Calibetimepiece said:
Good job. Honestly, first time saw this type of band.
Thanks.I have always loved leather straps ,but they do tend to separate and flexing them through the buckle and keeper are hard on the  leather. I am also not find of how they usually taper. I think the straight taper and snap  address these problems and simplify  fabrication.
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
