Smartwatch
I got this smart watch off ebay about 6 weeks ago for blood pressure, heart rate etc. My problem is when I work up a sweat the dial shows up a milky bloom, there is also some spots on the glass inside fungus?? and also what looks like the processor ? over heating??  and shows up when the dial is not showing time etc..I have got a couple of photos to show, best I can get that shows what is actually  happening... I emailed the seller and he said to send some photos which I did he cam back with can I take it to a watch repairer for them to check, surely the cost of fixing if it can be fixed will cost more than the £30 I paid for it..Am I right to say I don't want this watch repaired of replaced and ask for my money back. I know it's only £30 but know this can't be fixed or can it, I know nothing about watches..
Thanks for any help.. Len
On 6/28/2019 at 1:43 PM, yankeedog said:
Take the back off,set the watch in the sun.inspect gasket or for lack thereof. Replace or properly reinstall.
Hi,
Thanks for getting back to me and for the advice, I will try that now. I did not want to take the watch apart in case it invalidates the warranty, but just been informed that there is NO warrany, only for the first 30 days, Chineese rubbish. I know this is not our usual mechanical watches I only got this for the blood pressure and heart rate etc was not expecting them to say no warranty is given, I though all new goods had 1 years warranty..I will not be buying from them again,
Thanks again
Len
  • 1 year later...
Smart watches are the kind of thing that you need to order from the store. And only after you read the reviews on them. On ebey you could slip a defective watch. Unfortunately, this happens. I'd buy new ones if I were you. For example, I have a Michael Kors Sofie Smartwatch. I chose them very carefully and bought them only after reading the review on find your smartwatch. You can certainly fix them, but they will already be bad.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
