Smartwatch
I got this smart watch off ebay about 6 weeks ago for blood pressure, heart rate etc. My problem is when I work up a sweat the dial shows up a milky bloom, there is also some spots on the glass inside fungus?? and also what looks like the processor ? over heating??  and shows up when the dial is not showing time etc..I have got a couple of photos to show, best I can get that shows what is actually  happening... I emailed the seller and he said to send some photos which I did he cam back with can I take it to a watch repairer for them to check, surely the cost of fixing if it can be fixed will cost more than the £30 I paid for it..Am I right to say I don't want this watch repaired of replaced and ask for my money back. I know it's only £30 but know this can't be fixed or can it, I know nothing about watches..
Thanks for any help.. Len
On 6/28/2019 at 1:43 PM, yankeedog said:
Take the back off,set the watch in the sun.inspect gasket or for lack thereof. Replace or properly reinstall.
Hi,
Thanks for getting back to me and for the advice, I will try that now. I did not want to take the watch apart in case it invalidates the warranty, but just been informed that there is NO warrany, only for the first 30 days, Chineese rubbish. I know this is not our usual mechanical watches I only got this for the blood pressure and heart rate etc was not expecting them to say no warranty is given, I though all new goods had 1 years warranty..I will not be buying from them again,
Thanks again
Len
  • 1 year later...
Smart watches are the kind of thing that you need to order from the store. And only after you read the reviews on them. On ebey you could slip a defective watch. Unfortunately, this happens. I'd buy new ones if I were you. For example, I have a Michael Kors Sofie Smartwatch. I chose them very carefully and bought them only after reading the review on find your smartwatch. You can certainly fix them, but they will already be bad.
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
    • Ok thanks Ross, I will give that a try!😁
