Fitting generic Rolex crystals
I have a lady’s case style 69000A with a 2135 movt. I would like to install a generic sapphire with date bubble. I am putting the crystal inside the gasket rim and then I seat it on the case, but when I try to put the bezel in place to press it down, it is like the gasket is too thick. How are you all installing generic sapphires of this size?
I would double check the size of the generic crystal. Generic parts are notorious for being marginally different. The other issue depending on the watches age, a genuine Rolex crystal has a holographed Rolex logo at 6 o'clock which can be seen with the aid of a LED torch. If this is missing the watch has been devalued.
Providing it fits over the bezel and doesn’t foul the glass that should do the trick. Now it does make me wonder as you are having problems if it’s the correct glass.  Do you have the old glass? If so have you compared the two.
I have had trouble with generic crystals before on Rolex Oyster cases , some won't go for love nor money and others have fitted a treat. They have always been Sternkreuz crystals that i've used so I guess there manufacturing tolerances aren't that of Rolex.
Haven't tried a sapphire crystal though to be fair
   some watches are designed to only fit factory watches. i like to use generic plastic crystals.    my original batch of boxed  diameter, were made in India.   they seem to have gone out of busines.  they could be turned on the lathe to fit the lip.   vin
Thank you all for your input.
I have gone back at Old Hippy's suggestion and made a closer inspection of the two crystals.
The diameter on each is identical however, it appears that the quality of the rim cut to receive the ledge of the gasket is not as good on this particular generic.  Also, in measuring the gasket wall, excluding the larger portion that is supposed to fit in the crystal rim cut, the dimensions of the generic are thicker.
Genuine gasket wall thickness .47mm
Generic gasket wall thickness .52mm   This only adds to the circumference preventing the bezel from passing over this nicely.
IMG_1814.jpg?raw=1
IMG_1815.jpg?raw=1
Edited by GeorgeC
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
