No adjustment left on beat corrector
I'm wanting to regulate this movement. Usually I'd start with the beat corrector and when that's 0 or 0.1 max I'd move onto playing around with the rate in a few positions. However I've been stopped in my tracks because the beat error here is 0.5 and there is no more adjustment left.
Just wondering what my next move should be?
This is the time when you need to adjust the hairspring. It’s the next level up in complexity as you have to remove it, put the wheel on with the pin in the middle of the way and mark the spot on the wheel where the pin is located while the impulse jewel is right between the safety banks.
Thought to describe without pics! Maybe others will have images or a shortcut?
Good luck!
0.5ms beat error is a perfectly acceptable value and will not influence accuracy.
If you don't believe that, regulate to the best positions average, wear the watch few days and let us know.
Unless you are interested in learning how the hairspring collett is adjusted, which is a pretty delicate task, I would not recommend you try that on a balance cock with movable stud arm.
Edited by jdm
15 hours ago, AP1875 said:
There is however an issue with the pattern above. If the jump down repeats that's not a good sign, check if it  happens with a fixed period?
For a general reference I've the attached a brief guide. Only the first few pages are of interest, much better texts must exist.
Witschi Training Course.pdf
Thanks for sharing your knowledge. I uploaded a video. Probably the best way for me to show the pattern. What are your thoughts? Taking more notice of the pattern rather than the figures for beat error it doesnt look quite right.
I've checked all the parts when I took it apart, there isnt any damage to the escapement. Any ideas how to trace the fault and rectify it?
I will download the manual now thanks.
All is good with your watch. I'm so embarrassed, I posted with the brain disconnected, that is just the progress gap in your picture.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
