Seiko 5 Reference Numbers Not Matching ?
Hi Ladies & Gents
I hope you are all well
I picked myself up a Seiko 5 this week as a spares or repairs. It runs but stops intermittently and the plan was really just to use it as practice piece to strip down and fix up again.
I am relatively new to the world of Seiko model and reference numbers but I wanted to check in here first to see if you guys could shed any light on why the dial and case back numbers don't appear to correspond as I have read that they sometimes don't.
The dial numbers : 6319 - 495L R
Case Serial Nr: 551053
Case Movement Number: 6309-7320
I plugged the numbers into a Seiko date finder and it came back with May 1985, if the watch is a mix match though it may not be accurate. I'm suspecting it might have had a dial change at some point.
Any Thoughts ?
Many Thanks
Dave
You posted in "Your Projects, Walkthroughs and Techniques" but this actually belongs to "Your watch collection".
Anyway, your watch seem to be one of the infamous "Bombay special", made with whatever they had in had.
The dial, misalignment as it is, can't ever have belonged to a 6139, simply because that is a popular chronometer hence it has sub-hands.
You can check http://www.watchsleuth.com/seiko5finder/ as a Seiko 5 resource, however it is doesn't like any of the 6306 models like your.
Apologies for posting in the wrong section... but thank you for the info, I had a feeling that all was not right with it but in truth i really just wanted it for the movement. We live and learn.
53 minutes ago, ro63rto said:
The dial looks the same as a 7009-3101 gold sunburst dial so I think it's safe to say it is a Seiko one, just not from this watch.
Like this? But since it's printed 6139, it's fake. Not a big deal really. il_794xN.647694778_aa8b.jpg
Like this? But since it's printed 6139, it's fake. Not a big deal really. il_794xN.647694778_aa8b.jpg&key=26802f215db0cd080609d100895c7a77d04bd5e5482df04435dc4aecf987705d
But its not printed 6139 (chrono)
It's printed 6319
Even then, Seiko Oceania doesn't list a 6319 with dialcode 495L, only the 7009-3101.
So yes, a Feiko of sorts.
It's printed 6319
Thank you for correcting me. I have looked better at the OP picture, the dial is printed "made in Japan", to my knowledge Seiko has never printed dials with that?
Edited by jdm
The idea of wearing a Feiko doesn't sit all that well with me :biggrin: so I will just use the movement to practice on as was the original plan and put the case / dial in the spare parts drawer. I appreciate all the comments though, ill be a bit more observant buying Seiko's online in the future, fortunately it was very cheap.
Edited by Dave84
I find it nice overall, especially the case..You should see the really ugly ones!
For the best finds what Seikophiles do is to scour Yahoo Japan, but you will have to use a buying agent. I have a very good one myself.
'Seikophiles' :biggrin: any recommendations for agents ? could be fun searching through Japanese listings.
50 watches and counting (80% Seiko) and I haven't even ventured into Yahoo Japan except via a friend for an OEM faceted crystal for my LordMatic.
Well, I have dipped my toe in very recently after buying this one below in May, I have now been bitten by the bug and would like a 'few' more....
japonicamarket is good, cheap, and accomodating about declared value.
If you get a "whole lot" of Seiko 5 that will keep you busy for a good while, but there aren't many of these. Quartz, no name and ladie's lots go literally for pennies.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
