dropped my tweezers
AP1875
had a clumsy moment this afternoon and dropped my tweezers :pulling-hair-out:they landed tip first into my desk. As you can see from the picture the end is bent. How to i get them back into working order. Does anyone have a good tutorial or advice?
Using hammer straighten on anvil or any hard flat metal surface, then Grab a piece of sand papar with it, pull the sand paper out, repeat till you get the flat surface and the grab you want, next lay the sand paper on flat glass, as if holding something close the tweezers and reshape the outside and the tip. Avoid finer than original tip.
A good tip is one that dose not foul as you exert little excess force while holding a round object like a jewel.
I guess Whatever fine grit you got.
As the sand wears out, your sand paper gets better for the finish.
Do not hammer hard.
Hold tweezers prependicular to the surface to shape the tip.
Dropping is a part of tweezering:lol:.
Do not hammer hard.
    have you ever seen a Jeweler's   hammer?    vin
Hi Been there and had the same result,  They were gently hammered straight on a small anvil with stroking action towards the tips, then on to the wet and dry 120 grit to smooth and polish,  Now use general purpose tweezers for general work and my dumonts for the finer work and I am care full not to repeat the problem   all the best
 Dumont tweezers are superior to cheapy ones mainly by the hardness factor of the metal. Overbending so the tip needs to be streightened back, hammer or any impact that can cause intercrystaline dislocation hence fatigue is the main concern.
Avoid heat, impact or overbending. You can still get some use out of the bent section.
The sand grit and finish is a matter of your choosing, notthing to do with fatigue.
This is a subject of metalurgical structures.
Regards
