Trouble pressing case back on.
Examine the case back for burrs and damage.  You may need to lightly polish the edge of the case back rim with fine grit or a fine file to remove corrosion or other debris that is making things difficult. Ensure everything is sqeuaky clean before you proceed. The rear of the watch should be immaculate before you even attempt to put the back on. Any dirt or debris will find its way to the dial side eventually.
Check to see if there is a particular orientation the back is meant to fit in.
Apply a small amount of suitable grease to the edge of the back. Use a crystal press, but ensure you are  pressing on the body of the watch not the glass, as you don't want to damage the crystal.
Ensure everything is completely flat when pressing back on, and I do mean completely flat. The fit is often very tight, so if you have things slightly off true, then it will never go back on.
Edited by AndyHull
Another little thing as well as the above mentioned is make sure the caseback die is big enough , a to small a die tends to just exert pressure on the middle of the caseback therefore flexing the caseback edges out a little thus making the back bigger and harder to get on . You want the die to be as big as the caseback really and as also mentioned , some can put up a good fight
I use a drill press.  Plastic to protect crystal and case. Using  the largest socket that covers the case back ,I press the Chuck into the socket and press down. Plenty of leverage. Works every time.
Hi AndyHull,
Please, what would be a suitable grease for that, in your opinion? Would any of the greases we already have be good? Moebius 8200, molykote, or plain industrial vaseline?
I don't think grease will help, pay attention to what Ancyclient wrote above, the die must press on the perimeter only. You have a lathe so no problem for you to make a better die if needed.
Edited by jdm
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
    • unfortunately paying attention to details bumps up the cost. Which is why they shortchange on manufacturing steps if they can.
