8 day wall clock
Mattaphysics
So I recently got this wall clock for next to nothing... Of course there's a reason. It's all sorts of gunked up but it's also missing the minutes hand. I'm planning on getting a new set to my liking but i cannot tell how the minute hand is supposed to stay on. Out doesn't look like a nut screws on the end and i don't see a hole for a taper pin. Is it possible it's that gunked up that the hole is covered by dirt? Not sure if the pictures clear anything up. I don't believe it's missing any pieces to my knowledge. Just an American movement that doesn't have a strike train. And a thought just occurred... Is it possible for me to add a strike train if I wish later?
Sent from my LM-X210CM using Tapatalk
be068e72bc47b88454e309bbecc90960.jpg9402778aa31d45de99ecb6efca5f3565.jpg4db54efa7a0995483466fcee642044ed.jpg48037459f23b942095ce4152864faa57.jpg35d31c7bf5a8008e2d89ea93059b62fd.jpg
It’s a HAC movement Hamburg American Clock co and very popular in the collectors market. If it doesn’t have a strike or chime train then bestto leave it as is you can buy either for less than a conversion even if it was possible. Give it a good clean following a dismantle (loads on here about the procedure) Take lots of piccies, decide if it needs any rebushing and rebuild. A good starter movement.
spares should be readily available.
Good luck on the cleaning and servicing.
 As Squiffy says mind the spring, wind the spring up tight and fit a clamp if no clamp fit a strong wire around the spring and twist to secure before loosening the plates.  The Min hand looks like a push/friction fit Check  all the pivots and bearings, by the look of it one or two may need bushing. all the best
The minute hand should be pinned on. Have a good look at that square to see if the pin has broken off and is still in the hole. You will also need a hand collet to go over the minute hand and then the tow are held in place with a pin, use a steel pin not brass.
A close up of the hands arbour would help, I am not sure it has a pin because I can see no collar on the minute shaft, therefore it would rub on the hour shaft. That said it seems a large hand to be a pressure fit, a close up should help work it out.
First off thank you all for the quick responses and feedback. So looking at the minute pinion it doesn't look like you can tell at the end. It doesn't look like it takes a nut but i also can't see a clear sign at all. Here's dive pictures see if you can make heads or tails of it. Waiting for more cleaning fluid and alcohol for rinsing in the mean time. Is there a certain set of hands i need to get or just any for 5" dial will do?47516d93dc859f63069a9ce10ca1b248.jpg410c8a87460759e62c03f7e4c8374175.jpga661c4ca53833ff3fb49b4a556ffa55f.jpg
You need to see what clearance you have, this must include the dial the hands and if it has a bezel holding a glass.  I’m sure you know nothing must be touching each other. Would it be possible to shorten the hour pipe and have good clearance from the dial.
Looking at the clock dial it has no bezel therefore you can drill the end of the shaft and add a bit of steel. First file it to accomidate the minute hand and drill a hole for the taper pin, then solder it in place.
Yes, good idea! I fit have those materials yet. I've never soldered before so perhaps i should practice on something else beforehand. I believe i could just cut some of the hour pipe off then drill a hole in the minute pinion?
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
