Seiko 7002 Loosing Time
Hello there,
Im very new to watch movements but will love to restore this one i have eventually.
Im just looking for advice, my Seiko 7002 automatic Divers Watch seems to be loosing time, i think this my derive from the second hand occasionally stopping randomly.
I brought this watch from ebay last week and wear it all the time i also give it a 2 minute shake twice a day, so there cant be a reason that it isnt fully charged.
Is there an easy fix or will i have to strip down the watch and clean / oil it.
Kind regards, Ryan
Without it being put on a timing machine we can't really say, but if the second hand is occasionally stopping unless it is just loose which I doubt the watch probably needs servicing, which would require a complete strip down, clean and oiling.
I treat any watch I get from ebay especially including ones that state 'Has just been serviced' as most likely in need of a service
Hello there,
Thankyou very much for your promt response, I was afraid it might come to this, so ive prepared myself by recently purchasing an watch repair kit and oils.
I will first check to make sure the second hand is securely on.
I will most likely just follow restoration videos on youtube and get it overhauled.
Is there any reason why the watch also keeps a bad power reserve?
Kind regards,
A fault in the selfwind mech can cause poor power supply. Poor power reserve indicates a fault in the power reserve mech.
Test;  to find out the actual power reserve.
Wind full, manually through ratchet wheel by a screwdriver in ratchet wheel screw slot.The automatic mainspring will dislodge from the barrel wall and releases power at some point, you can here the sound of power discharge ( listen close) try to count the number of turns before the power discharge,  Wind again, stop just short of power release ( turns you counted before). Set the watch on bench, record how long it runs.
We,ll see you with the result. Regards
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
