Smiths Diver & Hello!
jaycey
First up the interesting part :)
1969/70 Smiths Diver made in Cheltenham today.
Not so interesting...
I am a training Horologist (EFHC) living in London. I am into my second year of training and progressing nicely.
My other interests are Open Water Swimming & Mountain Biking.
I am training as a hobbyist rather than a potential professional but when retirement comes in quite a while yet, who knows?
Up to now I have covered many hand wind movements with day/date complications including instant changers.
Quartz servicing.
I have covered a few Autos like the Seiko's, ETA 28-- series and have just begun my first chronograph, a ETA 7750 which is disassembled, cleaned and just waiting on some lubricants before I begin the reassembly.
Marks videos have been a great help to me and I thank you for them. Cheers!
Welcome jaycey, I love Smiths watches and Pocketwatches myself and currently have 3 watches plus numerous Pocketwatches in my collection...
Edited by daz
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
