Seiko crystal supplier in UK
Hello all. My wife has asked me to install a new crystal into her ladies seiko 7n83 0081. The crystal is very chipped and scratched. Im not fond on seiko, as to me they lack character. However on this occasion I’m rather bound to provide the required service [emoji38]. Question is, who is the best supplier in the UK for seiko crystals please and does anyone know the part number for upgraded sapphire crystal please? Kind regards Darren.
Thanks for your responses gents. I’ll check out cousins today, perhaps even give them a call now that I have the correct part number. Yesterday I pushed out the crystal but it just cracked under the stress. It was VERY scratched and chipped. I was surprised at just how much interference there was on the installation. I’ve managed to salvage the nylon ring which is is sandwiched between the case and crystal od. What I neglected to do prior to disposing of the broken crystal was measure its thickness. I will keep you up to date on how this on goes.
Hi. Just to update you with this. I found the crystal on cousins by chance. I find their search engine to be near useless. Even after finding the part by luck, I entered the cousins part number and it returned ‘no data was found’. I’m confused. However here is the part I found:
075bfebfdb2a80ef04f7ccde8e6e575b.jpg&key=c1887c4c40549d49f6b37608b046cd3f0804e10677e6fbfe079d6598916b60f0
So all that is required is to order and fit.
Kind regards
The crystal has a polymeric (maybe nylon) friction ring. Should this be installed around the crystal and then the sub assembly pressed into the case, or insert the friction ring into the case and then press the crystal in? The latter seems like it would be difficult, but I thought I’d just check. And lastly I’m assuming no lubrication is required as this might leave a messy residue.
Regards Deggsie
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
