Seiko crystal supplier in UK
Hello all. My wife has asked me to install a new crystal into her ladies seiko 7n83 0081. The crystal is very chipped and scratched. Im not fond on seiko, as to me they lack character. However on this occasion I’m rather bound to provide the required service [emoji38]. Question is, who is the best supplier in the UK for seiko crystals please and does anyone know the part number for upgraded sapphire crystal please? Kind regards Darren.
Thanks for your responses gents. I’ll check out cousins today, perhaps even give them a call now that I have the correct part number. Yesterday I pushed out the crystal but it just cracked under the stress. It was VERY scratched and chipped. I was surprised at just how much interference there was on the installation. I’ve managed to salvage the nylon ring which is is sandwiched between the case and crystal od. What I neglected to do prior to disposing of the broken crystal was measure its thickness. I will keep you up to date on how this on goes.
Hi. Just to update you with this. I found the crystal on cousins by chance. I find their search engine to be near useless. Even after finding the part by luck, I entered the cousins part number and it returned ‘no data was found’. I’m confused. However here is the part I found:
075bfebfdb2a80ef04f7ccde8e6e575b.jpg&key=c1887c4c40549d49f6b37608b046cd3f0804e10677e6fbfe079d6598916b60f0
So all that is required is to order and fit.
Kind regards
The crystal has a polymeric (maybe nylon) friction ring. Should this be installed around the crystal and then the sub assembly pressed into the case, or insert the friction ring into the case and then press the crystal in? The latter seems like it would be difficult, but I thought I’d just check. And lastly I’m assuming no lubrication is required as this might leave a messy residue.
Regards Deggsie
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
