Hello all. My wife has asked me to install a new crystal into her ladies seiko 7n83 0081. The crystal is very chipped and scratched. Im not fond on seiko, as to me they lack character. However on this occasion I’m rather bound to provide the required service [emoji38]. Question is, who is the best supplier in the UK for seiko crystals please and does anyone know the part number for upgraded sapphire crystal please? Kind regards Darren.
Can you remove it.? Think you can just buy  generic sapphire crystal to replace it with. Think it's 19 mm in diameter but not sure.
Correct
The first 3 digits denote the diameter
190 = 19.0mm
Thanks for your responses gents. I’ll check out cousins today, perhaps even give them a call now that I have the correct part number. Yesterday I pushed out the crystal but it just cracked under the stress. It was VERY scratched and chipped. I was surprised at just how much interference there was on the installation. I’ve managed to salvage the nylon ring which is is sandwiched between the case and crystal od. What I neglected to do prior to disposing of the broken crystal was measure its thickness. I will keep you up to date on how this on goes.
Hi. Just to update you with this. I found the crystal on cousins by chance. I find their search engine to be near useless. Even after finding the part by luck, I entered the cousins part number and it returned ‘no data was found’. I’m confused. However here is the part I found:
075bfebfdb2a80ef04f7ccde8e6e575b.jpg&key=c1887c4c40549d49f6b37608b046cd3f0804e10677e6fbfe079d6598916b60f0
So all that is required is to order and fit.
Kind regards
The crystal has a polymeric (maybe nylon) friction ring. Should this be installed around the crystal and then the sub assembly pressed into the case, or insert the friction ring into the case and then press the crystal in? The latter seems like it would be difficult, but I thought I’d just check. And lastly I’m assuming no lubrication is required as this might leave a messy residue.
Regards Deggsie
    • @Mark Thanks for letting me know. I'll start a new thread. @AndyGSi Thanks too for that tip. I might be able to turn them down if need be. 🤞
    • @AndyGSiThanks for letting me know Mate! 👍
    • Thanks for that Andy, Yes the new bracelet is worth more than the watch itself, Its one I have bought to service and clean-up and on-sell it as a project, look it may sell to someone who has a small wrist, I think I will buy an extender and may-be offer it up with a normal strap as well CJ
    • Not always that simple. Typically the only reason we would have any way of identifying a watch is if parts were available at any time and somebody had a parts reference book then they would help you to identify the watches that they have parts or. Unfortunately there are hundreds of thousands of watch movements with no identification and of course typically no parts the classic place were watches would be identified would be under the balance wheel and your pictures don't really show a good view of that. Occasionally I've seen watches marked under one of the plates. They felt very proud of their watch is a very prominent Swiss company and they ask he stamped the bottom of a plate so you have disassembled find it. Then there is the other system the keyless parts make up something called the fingerprint system but you still haven't given us enough information to make use of that. Here's an image showing what a fingerprint system looks like. The PDF is based on the physical book the physical book has sizes of watches these are smaller ladies watches and keyless parts which in the physical book are printed at the actual size of the watch parts. So to identify with the keyless we need in your case diameter measured on the dial side and a good picture of the keyless parts and then you have to hope that this was made within the right time span of the books that have this system on the other hand a lot of times on the dial side they will also put markings. So basically to identify a movement it has to come out of the case and has to be disassembled.
    • The strap is a 44Q6JB and hadn't realised how much they'd gone up in price. The used one I've got is very worn but may have other links floating around.
