Seiko 7009 - escape wheel not engaged
Dear All
I have faced this issue many times and I really hope that someone could help me. Thanks.
During assembly of the 7009 movement, many times I will be stuck with the barrel and train wheel bridge step. The problem I faced is that it is very difficult to have the escape wheel and pinion in perfect alignment. In other words the escape wheel is not engaged when I turn the barrel. (Steps 49 - 38).
I hardly ever encountered such issue with the 6309 or 7S26, but with 7005 and 7009, I am always stuck with this step, that is getting the escape wheel to be engaged when I place the barrel and train wheel bridge over. Can anyone share some reason/s why this is the case?
This step usually takes a bit of time. I think that the escape wheel has a tendency to lean against the third wheel, so before I install the bridge I try to be sure that it rests on the fourth wheel instead, then I put the bridge as as softly as I can. Then it always needs to be adjusted with the tweezers until the upper pivot goes into its jewel.
Hi James   fitting train wheels and bridges is always a bit fiddley, assemble the train  lay on the bridge softly then fit a screw into the bridge to hold it, do not over tighten it , hopefully this will hold the train wheels while you manouvre  them in.  I made some tools from soft sewing needles bent at different angles to allow me to jiggle the train wheels in.
Thanks for your replies.
Turns out I've had quite a number of bad escape wheels - broken pivot at the top or bottom, that's why it does not stay in position and so there's no engagement. Could be due to over tightening from previous attempts or they were already broken when I bought them as used watches. I tried with a good wheel today and somewhat managed to get everything in place.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
