7750 Part Question
Ive been working on 7750s for over a year now and have run across all sorts of variations etc but the lock 2 functions pn 8200 pictured below is a first. Anyone shed some light on it??acf37ae16451ef6e8cd63919cb5fd270.jpg
Sent from my SM-G950U using Tapatalk
I've never seen one like that on ETA 7750. Is it from a clone?
J
I dont know. I bought a spares and it came off it. Could very well be from a clone but the main plate is def an ETA. It seemed as though it was all original at least as far as I could tell.
I can't tell from the pic, but is it all metal? Likely a variant as you already know....all I found was an older Horotec guide with this (33 Var), but yours doesn't have the second cutout:
Its like a flat peice of plastice with a wire sticking out. Appears to be teflon or some soft plastic. I have a clone on the way so well see whats inside it. Thanks for looking into it. I wonder if itll perform as the normal one. I honestly dont see the advantage from a manf standpoint making it this way. It almost would seem like itd be more costly than the stamping that the eta parts are made from so thats why im curious.
It may be cheaper to cut out polyethylene  (cheaper than teflon) than to do stamping/grinding metal. It will be informative to see what the clone has, but I did see this on the 'bay so maybe it is ETA:
248220142_ScreenShot2019-05-29at11_54_56PM.thumb.png.a18040db575072d849f569948b0dd7dd.png
Edited by noirrac1j
I got a 7750 which turns out to be the original made by valjoux before the company was bought by eta. Dosn,t say eta7750 rather val7750. This varient too, came with plastic lever, Dr ranfft tells about the lever in diferent variants, I think the plasic is not a sign of inferior material or clone. Chrome plating is awful and I have never seen a balance wheel move this free in any movement.
Would you mind posting pics for the record????
I agree, however the secondary labor to install the wire is where the cost over run I think would occur as it would have to be done by hand. Anyhow.....it looks like the one I have is in fact an ETA part by your findings. This is good stuff for the 7750 body of knowledge. As always thanks for your input. BTW.....im ready when you are for the next iteration of 3D prints for your project. I posted my thread for the first Bronze CNC run. Im slowly getting up to speed on the CAM programming for the machine in fusion 360. If the machine will do what I think it will do we'll have metalic options at least in soft metals such as bronze.
1 hour ago, noirrac1j said:
So many watches, I sometime slose track of what I've overhauled, but I keep good records....I HAVE worked on a Valjoux 7750 with this same plastic part. It was a Lorenz chrono:
so it's the same as in my movement.....
Great information to have on the 7750. I am going to test a piece of curved plexi for the crystal and also have to try the drill holes for the stem/crown. I'll let you know when I get all that sorted out. Thanks!
J
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
