Late 1800 pocket watch - first attempt
Hi,
First I’m new at this.  So far I’ve taken a couple of cheap movements to pieces to get my head round the mechanics in tandem with the guidance in de Carle’s Book.
My first attempt at a restoration is on an late 1800 Swiss small fob watch that I picked up off eBay for spares or repair. The strip down has gone OK till I got to the canon pinion which I cannnot seem to budge and have stopped for fear of damaging it. Any advice on how to progress would be very much appreciated.
Additionally, the watch came with a minute hand in situe but with the hour hand broken off. The minute hand is 13 mm centre to tip.  Any suggestions as to the best route to source a new hand/ set of hands.  All new to me so don’t assume much knowledge.
Regards.850F8B95-4409-4E3B-8747-40046E6708F4.thumb.jpeg.f7bea8370b0643c3ae1d02cc243d73a9.jpeg
Lanski.
Hi Lenski   Cannon pinnions  are press  fitted  and can take a fair bit to remove them  with levers , but better with a removal tool as the pull must be straight to avoid damaging the center wheel, as regards hands  There are material houses such as cousins.uk    or gleave & co  A G Thomas where they can probably help, but a hand gauge or Micrometer is required to measure the hour wheel and cannon pinion to get correct size . Have a look at the Esslinger site on the web there is a help section which refers to measuring hands. A pair of pliers with soft brass jaw inserts can be used so as not to damage the cannon.
What you have is a five bar pocket watch movement. It is Swiss. If I’m not mistaken it is a cylinder escapement. It does not have pallets. You can remove the cannon pinion with a flat stake and small hammer. Tap the tip of the cannon pinion, it is a slim piece of steel that goes right through the center of the center wheel, it is friction tight.
I remember being similarly confused the first time I worked on that type of cannon pinion.  A normal puller might not work because of the smooth sides of the pinion. It can't get necessary purchase.
I've also used a brass hammer to get it started, sometimes following it up with a K&D sub-punch that will fit easily through the cannon pinion. You've just got to sight it from the side in order to get a solid eye-shot on the center pin (?). As Oldhippy said, a slight tap should do it. Good luck.
Edited by MrRoundel
Spelling
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
