Cartier Quartz dilemma
This is my own watch that I have owned for about 30 years. It stoped a little while back so I replaced the battery. It seemed ok but, I noticed it had stopped again after a short while. I have since tried the battery and it is ok, I also tried it on my quartz tester and there is a pulse. Many years ago it had to have a new movement fitted, as I did not wear it much I hadn’t noticed it had stopped and the battery had leaked. Needless to say I received a rather hefty bill from the goldsmiths because they sent it back to Cartier for the work. Even after that, as I hadn’t began my interest in working on watches and would never dream of opening it up, I still took it to the goldsmiths whenever it needed a battery. I didn’t want a repeat of the new movement scenario! So all in all I have spent a lot of money on the watch over the years, I still love it and try to wear it when I can. My dilemma is, a new movement from Cousins is about £250 +vat. Do I trust myself enough to strip it down and clean it?  Has anyone worked on these or similar? If it was something other than this watch I’d have no qualms about setting about it.
D6C49FB6-DFCA-4C70-8C23-88DB7787C097.thumb.jpeg.e9d64580d074c031cad7bca08332d68d.jpeg8B1993F7-5D71-44A6-B566-7CC0902CF38C.thumb.jpeg.0689f304e9ab3c8945d876301d0af414.jpeg
Caliber 690, classic tank style watch. Its a very nice, timeless design. I would try it, since you've nothing to lose, and it has no complications (date, seconds hand). I haven't done one in a while, but I have done several quartz watches in the past: mostly branded ETA modules, and they're not difficult. The hardest part is aligning the stepping motor in place because they're magnetic and tend to shift. I haven't done one in a while but I overhauled a friend's Movado (he wore it to the beach!) and after complete cleaning and brushing off the rust, I was able to get it working again. I simply used Moebius 9010 for the pivots and keyless works is just standard 9501.
Mark has a video of the ETA 955.412 that shows the fundamental process: quartz overhaul.
J
On the basis that you can't make it any worse, I would suggest introducing it to a demagnetiser the sort that basically has a magnet on an electric motor that "pulses" a magnetic field and spins the movement at relatively high speed thus clearing (relocating) any debris/sticky oil. This is not really a repair but it can revive an otherwise dormant quartz movement introducing some suitable oil in the right places as well may help.
Or if you are up to it you could tackle a strip/clean (a proper repair) as above.
I thought the same, got nothing to lose in having a go. I’ve done quite a few quartz anyway. You’re right though, the stepper is totally frustrating, sticking to everything. I have tried spinning it up with my quartz tester, it only ran for a short time and stopped. The movement has been in for over ten years now so I reckon it would be due some attention anyway. I’ve a couple of other things to finish up first, then I’ll have a go.
Interesting, and really handsome. It's probably the nicest quartz watch that I've seen. Dang, it even has nickel plates! That's a first that I can recall. Granted, I haven't been into wristies for more than 2-3 years or so. Pocket watches were my thing.
I'd consider getting some of the special quartz oil for that watch. Moebius makes a number 9000 that is specifically for quartz. It's pricey, but may be worth it. JMHO. Surely others will have different "O"s.
Good luck with your fine watch. Cheers.
Edited by MrRoundel
Punctuation change.
Like any mechanical watch with gears it needs to be serviced from time to time. These quartz watches are usually pretty simple easy to clean expensive if you break something. Then link with technical information does cross reference to a Ebel Which is handy if you're looking for parts gives you more parts options.  Then personally I do like Moebius quartz oil 9000 as it does work really well.
http://calibercorner.com/cartier-caliber-690/
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
