Lorus Stem Release
Phil1
Hi my names Phil and I live in Kent and have a small collection of watches (mainly Rotary and similar).
However, as most left-handers, I wear my watch on my right arm. So far I have successfully rotated the movements of a couple of cheap, unbranded watches bought from charity shops. Its now time to do the same to a Lorus watch ( "Y482-0020 [A1]" ). A watch which was bought for me by my parents over 30 years ago.
The problem is that I cannot release the stem. I have pushed everything and loosened every screw that look like it could do the trick but still it won't come out.
The movement says "SINGAPORE TIME PTE Ltd. Y482A L".
Can anyone please help?
Phil
I think I played with one of those movements a while back, and if memory serves me correctly then you push those two spring fingers at the top of the second picture gently apart while pulling the crown. I think you are meant to push a conical object (the end of a pair of tweezers presumably) in to the hole behind the spring fingers and in the process spread them apart.
Obviously be careful not to use too much force, I would estimate you only need to spread them by about 0.2mm to release the crown.
Perfect!
I use a screwdriver in between and parallel to the two fingers and rotated it gently while pulling on the stem. It came away with no problem at all.
Thank you so much. I would have probably ended up damaging it.
I'll let you know if it goes back in as easily.
Phil
Success!
It all came apart fairly easily. I had to grind two little spikes off the back of the face as they didn't line up in the new position and glue it back on.
The hands popped back on okay too. I chose this particular watch as it doesn't have a second hand.
The only casualty was the 1 o'clock baton. That'll have to go back on at a later date.
Thanks for your advice. I could not have done it otherwise. What a great site this is!
I'm now after some parts for a Gucci watch which I was recently given...in pieces. I hope I have as muck luck with that little project.
Thanks again,
Phil
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
