UTS Quartz movement
Davey57
Sorry, look away now OldHippy. I know you dislike them:lol:
A friend has asked if I can do anything with his wife’s kitchen clock that she loves dearly as it belonged to someone close. He says it was losing time although, it has been running perfectly with me for almost two weeks. Rather than give it back to find the problem returns I have been looking for a new movement. I have found one that is exactly the same here https://www.ebay.co.uk/itm/New-Replacement-UTS-01248-Quartz-German-Euroshaft-Movement-Mechanism-13mm-Shaft-/183725493748?_trksid=p2385738.m4383.l4275.c10&var=691309729771
Cousins have a one that I reckon should do, I just wanted to check. https://www.cousinsuk.com/product/hi-torque-uts
The only difference I notice is the distance from the front of movement to centre of shaft tip. Mine is 13mm same as the more expensive one, Cousins is 11mm.  Which should I go for please.
You could get one of each size from Cousins and by trial and error fit the one best suited. Also a suitable set of hands ordered at the same time would leave a spare complete movement and a repaired clock for less than the ebay item.
If the shaft is too long. You can always pack it with these sorts of washers. The large black type in this photo. Its always better to be a bit long than short. Just make sure you have good clearance of the face and the glass.
Not sure if this will inspire you further, but here are a couple of clocks I made from scrap.
The cloth balloon I made while I was fixing up our sewing machine, and the simple dinner plate one was as much an experiment in drilling holes in ceramic as anything else.
RIMG0263.thumb.JPG.4cb06d8bf76fc54634022b494dd13add.JPGRIMG0263.thumb.JPG.4cb06d8bf76fc54634022b494dd13add.JPG
The Chinese movements they use are cheap as chips on ebay.
There are a couple of others around the house, but these are probably the most off the wall designs I've done so far.
Cheers, I’ll have a look.  I’ve already bought a couple from Cousins plus a few sets of hands. When I have time I’m looking forward to making them into something. One thing though, the hands are a loose fit on the shaft of the movement. Is it normal to have to pinch them a little so that they hold?
I have a 20 year old clock with the same movement. I think it has a similar problem to the original poster. It keeps time, but occasionally falls well behind (in a dramatic way -- I think that it may stop for some minutes and then restart). Seems to happen more with semi-depleted battery, but not always.
I too only see the same replacement part listed on ebay -- assume this must be discontinued.
Have you found a correct alternative?  If so, can you let us know which model number movement is known to work?
  • 1 year later...
Hello Chippy and welcome to the forum.  There are m any suppliers of quartz clock movements, Cousins UK      H.S.Walsh both  material houses    or newgeneration clocks. on the links below.
https://ngclocks.co.uk/      https://www.cousinsuk.com/department/watch-parts       https://www.hswalsh.com/categories/watch-parts-straps-batteries
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
    • unfortunately paying attention to details bumps up the cost. Which is why they shortchange on manufacturing steps if they can.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  When it comes to tools buy the best you can afford a good set of watch makers screwdrivers if you look after them will last you a life time. I recommend Dumont tweezers Number 3 and number 5 for fine work, you can build up from there. You will need different strength eye glasses. Some now like to work using a microscope. Pliers the box jointed ones are best they don't go out of line.
