    • Hi i found this watch in second hand shop and would like to repair it. The hands are moving but not able to open the case. Also the watch is not working. If anyone knows how to open it please let me know.    I am new to this and collecting vintage watches   Raj
    • I think @oldhippy is right.   From wrestling with hairsprings this is one of the trickiest repairs to do, and when doing it one whish one saved the previous discarded part in the “good to have in the future box”. When it comes to replacing the teeth the donor piece has to come from a wheel not only with the same diameter but also the same type of teeth and depth on them, this is so you will get the correct amount of freedom for the wheels to rotate in a correct way. Even small differences like these ones will make the wheels not to run correctly in the length.   Another thing to consider is how to put the new piece in place. One should avoid making a rectangular shape to fit with and instead make a “dove tail” shape with a precision triangular file. Since the teeth on the wheel is subjected to lateral driving pressures a rectangular shape will eventually cause it to wriggle free and fall out, the solder hasn’t a very good mechanical resistance. This is just some small tips and tricks to think of when repairing wheels.
    • Uh ha this is more specific explanation Sent from my iPhone using Tapatalk
    • Hello, new member here from the Midlands. I've been a keen watch collector for some time and I like to wear a nice watch and have a small collection of modern watches. Then a few months ago I started looking at vintage watches and bought a couple, one specifically for my birth year (1972). Then.... this happened! I became a casualty of Covid and I have been made redundant. So with plenty of time on my hands and the need to keep myself mentally active i've decided to engage in the hobby further. I don't have transferable skills directly from my career but I am willing to give this a shot and see where it takes me. I ordered the equipment required to get started and completed Levels 1&2 of Mark's courses. My first major frustration was when removing the balance end stone the shock spring some how didn't hinge and came out, I picked it up with the tweezers and away it flew! So after an hour (or 6 ) looking for the spring and trying to find one to order I felt quite demoralised and gave up looking. The following morning whilst having a coffee at my work station I could not believe my luck, there it was blending into the work top. So all ended well this time but a real test/realisation for me as I embark on this journey. I've now started practising and yesterday dismantled my first project, which appears to have gone well with no flying parts... but there is a date complication so will be a new challenge in reassembly. I've added a little more equipment and today I should take delivery of a watch cleaning machine (without a manual ). Happy to be here and look forward to learning more and progressing my skills.
    • Hmmm well durability isn't exactly what people normally associate with gold, unless you're talking about its reactivity resistance so it doesn't tarnish for no reason.  The reason why your hands turn color has probably more to do with when you "gave friction" with the sand paper, it wore through the surface plating and exposed the yellow brass underneath. Not a problem if dealing with solid white-gold like in Rolex or anything that's not had a surface treatment of some kind.
