Vostok 2409 strange sound
Hello everyone. This is my first proper post here I hope someone can help me to identify this "issue".
I have a Vostok watch from the 80's with the 2409 movement. It keeps good time (within 3 seconds a day). Beat error is 0.1 ms and the amplitude fluctuates between 240° and 265° depending on the position.
The issue with the watch is that I hear a strange sound that only goes away when losening the balance cock screw. As soon as the screw starts putting the minimum amount of pressure to the balance cock the strange sound begins.
Currently I don't have the proper tools to handle the movement aside from proper watchmaker's screwdrivers so I cannot take out the balance cock assembly to check if something seems off.
I have attached two audio files, the first one with the balance cock screw properly tightened. The second one with the balance cock screw lose. Excuse the poor quality audio but is the best I could do with what I have available.
Hopefuly someone can help me identify this issue.
2409 sample 1.wav 2409 sample 2.wav
Having had a listen it's hard to say what the noise could be, it could simply be a little more amplified through the movement, it could be old lubrication starting to dry a little and a service, clean and fresh oil could resolve it, but i'd suggest it's nothing to worry over if you're getting accuracy to within 3 seconds a day currently.
Thank you for your reply m1ks. Taking the good performance of the watch aside I'm curious about the origin of the sound. My only concern about it is that whatever is causing the sound may be causing premature wear on some components.
About a month ago I needed to buy a new strap so I went to my watchmaker to had it changed. It never crossed my mind to ask him about the sound at that time but I told him to take a peek at the movement to see if everything was alright. He said everything was clean and properly lubricated. He only pointed out that the balance had a bare minimum amount of play/wobble but that it shouldn't affect the performance of the watch. Taking into consideration that the sound only happens when the balance cock screw is properly tightened and goes away when the screw is lose maybe the issue is related to that behaviour of the balance.
I also though about what you said about the sound being amplified through the movement and case. Considering the movement is held by two screws to the metal spacer ring but not to the case itself. Maybe when I get the proper tools I'll investigate more deeply into this subject. Thanks again for your help.
Edited by Seishin
Adding more information
Russian watches sometimes have a shim to set the balance-staff clearance. If it was missing you may have too little end shake but I would imagine that that would result in the watch stopping, not making noises.
This post below has a picture of a shim but on a different movement. Something to think about.
Good luck
Anilv
Good luck
Anilv
Hello Anilv.
What you say makes a lot of sense to me. If my particular watch had a shim maybe it wasn't replaced when it was last serviced. But as you say, if the balace pivots have less end shake due to the missing shim the balance should stop or at least have difficulty rotating back and forth, not making noises. Strange indeed. I wish I had another 2409 movement or similar ones to make a comparison of the sound. I might even start to believe that this is how russian watches sound.
Thank you for taking your time to reply. Have a nice day.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
    • The two measurements of particular importance wound be the height and the strength,  the length would obviously correspond with the increase/reduction of half mm of barrel diameter. There is a big difference in price considering that the more expensive one is the shortest. The longer one might be ok ? But then it is taking up more room in the barrel, might it effect the unwinding ? I wouldn't have thought so for just that small amount.  Ideally a pro might reduce the longer one to suit. But there is some information that might help, do you have the one that was fitted to measure up, though not necessarily the right one.
