Help needed with sweep seconds
I have an Elgin 532 produced from 39-44. It’s a non hacking military movement which was the predecessor of the 539. I serviced the movement, and reassembled. Watch ticks great but second hand is very jittery it doesn’t sweep as it should. Center wheel and pinion looked fine. I also made sure sweep bridge screw was tightened. The second hand is secured to the pinion, it’s not loose at all. When it ticks I can see the center wheel turning smoothly so I can’t understand why the hand would act like it’s loose. And last but not least the hand is not hitting anything it’s acts the same way out of the case and is spaced well enough away from the minute hand any ideas?
I've not worked on one of these but a quick Google and the found pics show it as an indirect centre seconds movement. These almost always have a tension spring of some kind that acts on the seconds pinion to prevent the jittery motion of the seconds hand.
Rare-Vintage-1942-ELGIN-WWII-15J-532-_57.thumb.jpg.adabdf2170dc42eb08266b9368d3ebfb.jpg
In the above you can see circled in red a screw that passes through the centre seconds cock and appears to bear on a flat spring. My guess is that that is the tension spring and the tension is adjusted with the screw.
try turning the screw to increase the tension on the centre seconds pinion until the jittering just stops. You may need to lubricate the contact between the spring and the pinion if you haven't already done so. The tension needs to be just enough to smooth out the motion of the hand whilst keeping loss of amplitude to a minimum (there will be some loss, it's unavoidable).
did not think of that. great will try this out and update the post
I couldn,t find on ranfft, the caliber sasswatch talked about , didn,t know see the looks of it.
I have around fifty movements of this design made by fhf , in fact most any producer made this design. Have worked on many.
  @Marc  you are right about the spring and center second,  in case of improper oiling, even if it runs good now, it may anytime impede the movement.
Everytime I removed the min wheel, the wheel fell off couple of months later. Proper tooling and skill is a must.
It looks like you already have gotten the help you need, but I am interested to hear about this movement as I was not aware of it as its not mentioned in any of my reference books of Elgin wristwatches used by the military.
I have in the post coming a small collection of NOS parts for Elgin 580 and 554 military watches, and will now need to keep an eye out for a 532 too.
I'm only really just starting to learn about American military watches, but already have a small collection of American military aircraft clocks and one naval deck clock
the 532 was limited production for the military, only a few thousand pieces made, and they were only made for the marines with the white dial. If you google search USMC elgin 532 you will see it. I have seen black dial versions but I believe they were for civilian use. The watch was quickly replaced with the 539 since the 532 was a non hacking movement. The 539/ and other A-11 movements started the whole military hacking movement wave. It has since been the standard for any military watch.
I had the same problem on a Longines and it's what Marc described. It's that little spring that presses on the pinion or whatever it's called that the seconds hand is attached to on the other end.
On mine I had simply misadjusted it.
Edited by Chopin
YEA I adjusted mine and now its good
    • Haha. You're just in a wicked mood today John 😅
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
    • I have a PDF below that will help. The problem was the PDF wasn't designed for this purpose it was designed to tell you what size watch you  have. Then it doesn't take into account movements come conceivably in different thicknesses.   watch-ligne-size-chart.pdf
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
