Help needed with sweep seconds
I have an Elgin 532 produced from 39-44. It’s a non hacking military movement which was the predecessor of the 539. I serviced the movement, and reassembled. Watch ticks great but second hand is very jittery it doesn’t sweep as it should. Center wheel and pinion looked fine. I also made sure sweep bridge screw was tightened. The second hand is secured to the pinion, it’s not loose at all. When it ticks I can see the center wheel turning smoothly so I can’t understand why the hand would act like it’s loose. And last but not least the hand is not hitting anything it’s acts the same way out of the case and is spaced well enough away from the minute hand any ideas?
I've not worked on one of these but a quick Google and the found pics show it as an indirect centre seconds movement. These almost always have a tension spring of some kind that acts on the seconds pinion to prevent the jittery motion of the seconds hand.
Rare-Vintage-1942-ELGIN-WWII-15J-532-_57.thumb.jpg.adabdf2170dc42eb08266b9368d3ebfb.jpg
In the above you can see circled in red a screw that passes through the centre seconds cock and appears to bear on a flat spring. My guess is that that is the tension spring and the tension is adjusted with the screw.
try turning the screw to increase the tension on the centre seconds pinion until the jittering just stops. You may need to lubricate the contact between the spring and the pinion if you haven't already done so. The tension needs to be just enough to smooth out the motion of the hand whilst keeping loss of amplitude to a minimum (there will be some loss, it's unavoidable).
did not think of that. great will try this out and update the post
I couldn,t find on ranfft, the caliber sasswatch talked about , didn,t know see the looks of it.
I have around fifty movements of this design made by fhf , in fact most any producer made this design. Have worked on many.
  @Marc  you are right about the spring and center second,  in case of improper oiling, even if it runs good now, it may anytime impede the movement.
Everytime I removed the min wheel, the wheel fell off couple of months later. Proper tooling and skill is a must.
It looks like you already have gotten the help you need, but I am interested to hear about this movement as I was not aware of it as its not mentioned in any of my reference books of Elgin wristwatches used by the military.
I have in the post coming a small collection of NOS parts for Elgin 580 and 554 military watches, and will now need to keep an eye out for a 532 too.
I'm only really just starting to learn about American military watches, but already have a small collection of American military aircraft clocks and one naval deck clock
the 532 was limited production for the military, only a few thousand pieces made, and they were only made for the marines with the white dial. If you google search USMC elgin 532 you will see it. I have seen black dial versions but I believe they were for civilian use. The watch was quickly replaced with the 539 since the 532 was a non hacking movement. The 539/ and other A-11 movements started the whole military hacking movement wave. It has since been the standard for any military watch.
I had the same problem on a Longines and it's what Marc described. It's that little spring that presses on the pinion or whatever it's called that the seconds hand is attached to on the other end.
On mine I had simply misadjusted it.
Edited by Chopin
YEA I adjusted mine and now its good
    • I have it, so until we get a lunch one day , nearly everyday is with my mum at the moment.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
