Help with Lower Jewel fitting
I am working on a Illinois 12S Aristocrat pocket watch and the previous maintainer simply dropped a jewel in the pocket for the lower balance jewel; resting on the jewel end cap. I think the plate requires a friction fit jewel setting with the cap jewel, so I found a setting that sort of fits with a jewel that is the right hole size. So should I just go ahead and press in this setting? Anyone experience this situation before. I did not think that there were pressed in lower Balance jewel settings. My watch is the third model.42a7dd060f322825cf6b91a6eabaf79a.jpg1f951b80270f81354efc0fb96c6c5a40.jpg76fb62ec64573dee995f53fe2e8741d5.jpge6926e4dbbe89fa3d5a7b63ee85463cd.jpgNot presses in yet.3ea2007563cc7a4016aa69c983c1e9c7.jpg
the lower  jewel in some vintages elgin pocket watch balance staffs  have caused a problem for me.   one experence;   bought a watch that appeared to have a broken balance staff,  on dissassembly,  the staff was in tact with the lower jewel pushed out.   this could have hapened when the former owner pushed the jewel down when fitting the balance cock.?  vin
Was it friction fit in place? This one appears to be a friction fit, even from the data I included.
   that became a parts watch,  i did not try to adjust the jewel.  i have another mvt.. ill look into it.
I think the proper place for this would be in "watch repair questions and advice".
Anytime were working with American pocket watches it's nice to have the serial number especially when looking for parts. Then because this is not your normal 12 size it's extra thin looks like you're right it's a friction jewel setting.  So image extracted from a listing so we get the diameter and the thickness. Then the other minor problem with Illinois all the different part numbers to make for a confusing mess.
Thanks for the data. Friction fit is odd.
Sent from my GT-N5110 using Tapatalk
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
