Scrollsaw Cuckoo Clock
GregC
6 hours ago, JimmyD said:
It depends on the type of movement you are putting in the clock, battery or brass?
The first will be battery as 10 yrs ago when I was all gung ho for scrolling I bought everything for 3 clocks. Now that I'm closer to completion I'm thinking I could make the cavity deeper to fit a real cuckoo mvmt. I just need to know if they are a standard height
Regula make a 1 day and 8 day movement, these can be bought at time savers. A few things you need to know, the depth, the movement will need to be screwed to the inside of the face board, so about 6 mm think blocks need to be glued on to take the screws, then add the distance from the mounting bracket to the tip of the crutch, then add another 50mm so you have enough room for the cuckoo belows. The hight is dictated by where  the hands arbour hole is placed on the face. The width you have already since you have made the frets. Have a look on eBay at cuckoo clocks for sale to see how they are normally set up on the inside to give you an idea.
First one is going to be quartz. I just measured the darn thing and forgot the dimensions. I think its 4" wide by 6" high. Original plan has it 2" deep but I can alter it to make it deeper.
36 minutes ago, JimmyD said:
I think the 1st photo looks better with more of a contras, just remember to put the dial with the 12 at the top.
I thought so too but I just realized how the color is like that. I didnt read the directions for the stain and didnt wipe the excess off thats why its so dark. I hope these old messed up brains can remember to put XII at the top, lol  ;-)
Now that this project has been completed, I hope that some of you might be inspired to pick up a scroll saw and try out this craft. Its not hard, just tedious and repetitive but you can make some beautiful pieces of art and there are all kinds of patterns out there for everything one could imagine. This clock is not difficult at all, there are clocks that take guys months or even years to make. Cherry tree toys has the most awesome patterns I've come across and Berry basket has some simple yet beautiful stuff, in fact this clock is from a pattern by Cherry tree toys.
https://cherrytreetoys.com/scroll-saw-patterns/
https://www.berrybasket.com/
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
