Canon pinion removing issue
Guess that is an pocket watch with a press fit canon pinion?
You probably need a staking set and gently tap it out.
(P.S . Nexttime just post in the Watch Repairs Help & Advice, makes everything easier)
Edited by HSL
Well the thing with this tool is so you can align it straigt but I guess everything you could use to get the same effect goes.
The cannon pinion is slightly conical so you only have to get the second wheel to go downwards in a gentele way.
Will attache a picture so you get the idea.. (Here I am pressing it back).
