I have never used 'Fixodrop" but I have read a few posts of late recommending its use. I read somewhere that it can be used on the end of oilers to enhance the drop of oil being applied.
So my questions are
1) Is it really that good.
2) How do I apply it & where.
Your thoughts guys would be much appreciated.
Somewhat hijacking your question I find this an interesting subject in that it's not always that visible on the normal service tech sheets. The reason I'm pointing this out is we usually try to follow whatever the manufacturer recommends but if we are unaware that the parts have been surface treated to prevent the spread of oil and we use the oil they recommend without the surface treating the oil is much more likely to spread.
So I'm attaching some images two of them are from an Omega 1957 guide on lubricating their watches. Even though it's a lubrication guide is spends quite a few pages on cleaning the watch because that is a requirement before lubricating. So in the fifth jar of their cleaning machine they have the epilame. Then I've attached some images from that guide telling you what they would use it on and the write up. On the write up I've circled what they're not using it on. Then you'll notice there's a discrepancy between modern surface treating which is the surface treat the pallet stones and their recommendation to not.
Then ETA used to publish manufacturing guides for their watches in addition to their tech sheets. Manufacturing guides are really interesting in that they tell all sorts of technical specifications. So I've attached the interesting part for us and highlighted where surface treating is being used. What I find interesting is the balance staff is treated.
Then some links one explaining about the various substances. Another explaining of the cautions. The problem with the solvent is when it evaporates the parts get cold there is a possibility of condensation which conceivably could lead to rust.
http://watchmakingblog.com/2011/07/29/one-hazard-of-epilame/
http://hiro.alliancehorlogere.com/en/Under_the_Loupe/Epilame
Then on page 7 of this document the special bottle that you're supposed to have aMicrophone off microphone offnd how to use it.
http://www.bhi.co.uk/Documents/certificate/Tech/PractLub.pdf
Than as Eta surface treated the balance staff to prevent the spread of oil incabloc Uses it on their jewels and they talk about it at the link below.
http://www.incabloc.ch/en/huilage.php
Please let us all know how you get on... and how long your first £85 lasts before it evaporates away.
Does anyone know of a cheaper alternative? I bought a nice Record 9ct gold watch for less than that recently, and the watch didn't need an extra £100 for a special bottle, just £20 for a new strap.
S
Must ad
S
Must admit Stuart I did not realise the cost of this magic elixir.  It will have to really make a difference for a purchase.
So in this first link somebody is doing experiment between the different brands although they did leave out one of the brands.
http://forums.watchuseek.com/f6/zenith-epi-kote-vs-fixodrop-epilame-treatment-1310626.html
Then as far as costs goes it varies. Towards the bottom I have the comparison of commercial products and Zenith appears to be cheaper.
Then there are other ways to do this for instance there was once a watch cleaning machine that was rather unique as it used isopropyl alcohol which it distilled with each use. Then it had a special heating chamber to vaporize stearic acid. I had read a patent on the vapor process and it's supposed to be really nice in that the coating is very uniform and Much thinner than by dipping. The other problem with dipping is as the bottle is evaporating the concentration is increasing. Then I know someone that was in a school situation where the cost of the commercial was expensive and they were making their own solution I'll have to send an email off and inquire as to how well that really worked and see if I get a formula.
So here are links to the various companies that make this stuff.
http://www.zenithsolutions.net/productlist.htm
http://www.lrcb.ch/produits/produits.html
http://www.lrcb.ch/produits/epilames/presentation_epilame_eco50.pdf
http://www.epilamisierung.com/index.php/en/
http://www.moebius-lubricants.ch/en/products/epilames
So for price comparison you'll need a bottle of this for $135 plus the nifty bottle for applying it at $78 dollars.
http://www.jewelerssupplies.com/product1015.html?_ga=1.247603968.686915199.1434009467
Then if you using the eyedropper method for the pallet stones this is a must have
http://www.jewelerssupplies.com/product5586.html?_ga=1.84618270.686915199.1434009467
Then Zenith is cheaper  For both the solution and the special jar.
http://www.jewelerssupplies.com/product9513.html?_ga=1.45304739.686915199.1434009467
http://www.jewelerssupplies.com/product8704.html?_ga=1.121316495.686915199.1434009467
  • 2 years later...
So I have been getting a couple of watches back that are running perfectly fine after I service them and then a couple of months go by and the clients call me up to say they either stopped running or they are running too slow or too fast. Could i be because I am not using Epilame on the cap jewels that the oil is spreading and causing these problems? I just find it funny that they run perfectly fine when i put them on my timing machine and then i happen to get them back. Thanks
Maybe. I had an issue with my Rolex (3135) I serviced it and it worked great for 12 months + but then now & again the auto side did not keep the watch wound. I was confident that it had serviced the watch correctly & with the correct oils. The only thing I did not do was to Epilame the reversing wheels of the auto. I stripped the auto works cleaned and lubed & Epilamed the reversing wheels and it has worked perfectly since for over 2 years +. I have never used it for cap jewels and had no issues. Some recommend using it on the pallet stones run it for a while, then  strip again clean the escape wheel and lube the pallet stones again. I have done this but could not see the benefit.
Hello. I am considering buying a bottle of fixodrop and I found that there are many options regarding the quantity.
Since I am hobbyist watchmaker, I don't service a watch very often.(Couple of them in a month)
In this case, would it be okay to purchase the smallest amount of fixodrop(1ml)?
One more thing. Is there anything else I should get to apply the fixodrop to my pallet fork?
As a hobbyist the usual recommendation is it's a waste of money.  Usually the fluid is taken out of the bottle and either goes in the special bottle at the link below or the eyedropper bottle. One milliliter isn't going to be enough to take out of whatever it comes in. If you just dip the party in or dip the pallet stones then really fast you might Be able to get by but I think this is a be a waste of money. The problem is the solvent they use is extremely volatile Every time you open the bottle a little bits going to evaporate it just isn't going to last very long.
Then there are other alternatives that it's cheaper the third link has a cheaper option.
https://www.jewelerssupplies.com/epilame-bottle-double-chamber-for-fixodrop-150.009.html
https://www.jewelerssupplies.com/kimble-amber-glass-bottle-with-dropper-150.006.html
https://www.jewelerssupplies.com/zenith-405-epi-kote-epilame-30ml-420.130.html
I use fixodrop on watch reversing wheels. I also use the special fixodrop application bottle. I have tried it on pallets. However you have to apply it just to the pallets stones. Then run the watch for a while then remove the balance, pallet and escape wheel and re-clean the escape wheel and re-assemble. I did this with a couple of watches but did not see any benefits.
Wow thank you for your recommendations. I will consider getting those instead.
Would applying the fixodrop on the pallet stones with an oiler and letting it dry work?? If fixodrop is inside a bottle, how can I be sure only pallet stones is affected?
Edited by east3rn
I have read there is problems when applying fixodrop to the whole pallet.  I applied it to the an oiler and dried gently with warm air being aware too much heat will dislodge the shellac. I read somewhere some use a dropper.
However as I stated in a previous post I see no significant benefits so I longer bother treating the stones.
I thought you might find this link interesting
Then two separate images attached. 1957 Omega's guide on oiling watches covers cleaning and surface treatment. Here you get the answer to why some stuff isn't treated. Then Omega in 2012 showing dipping preferred. I think the eyedropper method would work fine. Then of course immediate warm air drying.
So surface treatment prevents the spread of oil and has been used by watch companies for a long time. This means they can use lubricants that have a likelihood of spreading because are relying on the surface treatment. Which means if we follow their lubrication guidelines without surface treating conceivably we will have problems.
As an alternative for the pallet fork you could try this strangely enough it's not actually listed as an oil.
https://www.cousinsuk.com/product/moebius-9415-for-pallet-jewels
That was the article I read. I found no benefit after applying the Epilame to the pallets.
Edited by jdm
Please don't include pictures in quoting
  • jdm featured this topic
  • 9 months later...
Don’t forget a lot of us have to pay 20% VAT on top, so call it £162. I made my own with an unused (;)) sample bottle and a small metal screw top container, it seems to work fine.
Stephen
PS it’s epilame :)
Sorry about the spelling & yes alternative methods will be needed. I purchased my one A few years ago I now wish I had purchased dozens
  • Similar Content
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
