Where to buy bezel type (rub in) jewels
I've got a Unicorn 1920s watch that I'm treating as a long term project as it has numerous issues and after cleaning the movement yesterday I discovered I had 3 cracked jewels that will need to be replaced and they are the bezel (rub in) type.
It is one train jewel and the two balance end stones, its even possible the cover stones are chipped too as I haven't removed them yet to check they are ok.
I've got the tools for opening up the bezel and still chasing a set of closing tools, but if needs be I could always make something to close the bezels.
Looking at Cousins they only seem to sell the modern friction fit jewels, is there anywhere that sells the bezel fit jewels or is it a matter of trawling Ebay for New Old Stock?
I buy most of my supplies from Cousins UK, they only sell friction fit jewels, and yes they are expensive.
Guess I will trawl ebay for NOS rub in jewels, no rush on this project
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
