A toolbox
Squiffything
I’ve had down the shed a box that I’d saved from the skip years ago. I’ve always intended to do something with it one day so decided that that day had come. I need something to keep my tools in and thought that might be ideal for what I require. So from a pile of wooden parts split lid, scratches etc i now have a little toolbox
Fitting a key to a lock is not hard, This lock should be a lever type, just take the lock off,, take off the cover plate and you will see 2 or 3 levers, start with the bottom lever, file a key that will lift the lever over the post and move the bolt , put the 2nd lever back on, repeat, and so on.
Cheers Jimmy I’ll have a look.
The day has been fruitful carrying on and finishing the toolbox. It originally had a life as a canteen of cutlery and had a old scruffy blue velvet or felt like material and loads of wooden partitioned sections for all the knives forks and spoons. Some had fallen out the material was ripped and it looked in a sorry state.
As it’s for tools it doesn’t need a material inlay just something that covers the wood and give a little protection. I decided on thick card stock and in the deep drawer a sheet of foam core board. I’m pleased with the outcome.
Quick tool tip for cutting material (cloth, leather, thin plastic sheet, cardstock etc).
Get a quilters rotary cutter (available from the usual suspects) and a steel ruler. You get perfect straight cuts, with clean edges. It works with larger sizes, multiple layers, and materials that wont go in a guillotine.
The only thing I would advise. Get in the habit of using the guard on it, or you may end up picking your fingers up off the floor, or wondering where all the pretty red ink is coming from.
Not everything came with it, I’ve been buying a few extras but the lathe and mill attachment and most of the Emco stuff with the original lathe were there.
Ive also purchased two upgrade motors and associated bumph to improve it by turning it into variable speed on separate independent  motors for the lathe and mill. Just waiting for the PSU unit to turn up to fit that all together.
1 hour ago, oldhippy said:
You have the saw and indexing attachment plus a knurling tool. They are the parts I don’t have.
I have lots of other attachments. I'm always looking on ebay. The prices are way to high.
The knurling tool isn’t an Emco product but it will fit in the toolposts so I can use it. The saw was a mistake purchase. It’s one for the SL so the fitting isn’t correct. They did two for the SL one of which is totally different. This is the same shape and design as the U3 one however the fitting plate is wrong. The actual saw unit unbolts from the fitting plate so I should be able to fabricate something.
OMG another subject of the Unimat 3 :) and very well equipped nevertheless!
I've got a SIEG C0 myself and become a bit fixated about. I'm learning with it, have many ideas About self-made accessories, which as noted do cost a good deal. I'm in contact with another well known enthusiast, maybe we should find a place to swap ideas and projects.
BTW the wooden box is  great, I left something similar behind when moved. But then got the below, it was filled with a million of plastic  tubes for stems. If anyone wants some just let me know.
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
