A toolbox
Squiffything
I’ve had down the shed a box that I’d saved from the skip years ago. I’ve always intended to do something with it one day so decided that that day had come. I need something to keep my tools in and thought that might be ideal for what I require. So from a pile of wooden parts split lid, scratches etc i now have a little toolbox
Fitting a key to a lock is not hard, This lock should be a lever type, just take the lock off,, take off the cover plate and you will see 2 or 3 levers, start with the bottom lever, file a key that will lift the lever over the post and move the bolt , put the 2nd lever back on, repeat, and so on.
Cheers Jimmy I’ll have a look.
The day has been fruitful carrying on and finishing the toolbox. It originally had a life as a canteen of cutlery and had a old scruffy blue velvet or felt like material and loads of wooden partitioned sections for all the knives forks and spoons. Some had fallen out the material was ripped and it looked in a sorry state.
As it’s for tools it doesn’t need a material inlay just something that covers the wood and give a little protection. I decided on thick card stock and in the deep drawer a sheet of foam core board. I’m pleased with the outcome.
Quick tool tip for cutting material (cloth, leather, thin plastic sheet, cardstock etc).
Get a quilters rotary cutter (available from the usual suspects) and a steel ruler. You get perfect straight cuts, with clean edges. It works with larger sizes, multiple layers, and materials that wont go in a guillotine.
The only thing I would advise. Get in the habit of using the guard on it, or you may end up picking your fingers up off the floor, or wondering where all the pretty red ink is coming from.
Not everything came with it, I’ve been buying a few extras but the lathe and mill attachment and most of the Emco stuff with the original lathe were there.
Ive also purchased two upgrade motors and associated bumph to improve it by turning it into variable speed on separate independent  motors for the lathe and mill. Just waiting for the PSU unit to turn up to fit that all together.
1 hour ago, oldhippy said:
You have the saw and indexing attachment plus a knurling tool. They are the parts I don’t have.
I have lots of other attachments. I'm always looking on ebay. The prices are way to high.
The knurling tool isn’t an Emco product but it will fit in the toolposts so I can use it. The saw was a mistake purchase. It’s one for the SL so the fitting isn’t correct. They did two for the SL one of which is totally different. This is the same shape and design as the U3 one however the fitting plate is wrong. The actual saw unit unbolts from the fitting plate so I should be able to fabricate something.
OMG another subject of the Unimat 3 :) and very well equipped nevertheless!
I've got a SIEG C0 myself and become a bit fixated about. I'm learning with it, have many ideas About self-made accessories, which as noted do cost a good deal. I'm in contact with another well known enthusiast, maybe we should find a place to swap ideas and projects.
BTW the wooden box is  great, I left something similar behind when moved. But then got the below, it was filled with a million of plastic  tubes for stems. If anyone wants some just let me know.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
