A toolbox
Squiffything
I’ve had down the shed a box that I’d saved from the skip years ago. I’ve always intended to do something with it one day so decided that that day had come. I need something to keep my tools in and thought that might be ideal for what I require. So from a pile of wooden parts split lid, scratches etc i now have a little toolbox
Fitting a key to a lock is not hard, This lock should be a lever type, just take the lock off,, take off the cover plate and you will see 2 or 3 levers, start with the bottom lever, file a key that will lift the lever over the post and move the bolt , put the 2nd lever back on, repeat, and so on.
Cheers Jimmy I’ll have a look.
The day has been fruitful carrying on and finishing the toolbox. It originally had a life as a canteen of cutlery and had a old scruffy blue velvet or felt like material and loads of wooden partitioned sections for all the knives forks and spoons. Some had fallen out the material was ripped and it looked in a sorry state.
As it’s for tools it doesn’t need a material inlay just something that covers the wood and give a little protection. I decided on thick card stock and in the deep drawer a sheet of foam core board. I’m pleased with the outcome.
Quick tool tip for cutting material (cloth, leather, thin plastic sheet, cardstock etc).
Get a quilters rotary cutter (available from the usual suspects) and a steel ruler. You get perfect straight cuts, with clean edges. It works with larger sizes, multiple layers, and materials that wont go in a guillotine.
The only thing I would advise. Get in the habit of using the guard on it, or you may end up picking your fingers up off the floor, or wondering where all the pretty red ink is coming from.
Not everything came with it, I’ve been buying a few extras but the lathe and mill attachment and most of the Emco stuff with the original lathe were there.
Ive also purchased two upgrade motors and associated bumph to improve it by turning it into variable speed on separate independent  motors for the lathe and mill. Just waiting for the PSU unit to turn up to fit that all together.
1 hour ago, oldhippy said:
You have the saw and indexing attachment plus a knurling tool. They are the parts I don’t have.
I have lots of other attachments. I'm always looking on ebay. The prices are way to high.
The knurling tool isn’t an Emco product but it will fit in the toolposts so I can use it. The saw was a mistake purchase. It’s one for the SL so the fitting isn’t correct. They did two for the SL one of which is totally different. This is the same shape and design as the U3 one however the fitting plate is wrong. The actual saw unit unbolts from the fitting plate so I should be able to fabricate something.
OMG another subject of the Unimat 3 :) and very well equipped nevertheless!
I've got a SIEG C0 myself and become a bit fixated about. I'm learning with it, have many ideas About self-made accessories, which as noted do cost a good deal. I'm in contact with another well known enthusiast, maybe we should find a place to swap ideas and projects.
BTW the wooden box is  great, I left something similar behind when moved. But then got the below, it was filled with a million of plastic  tubes for stems. If anyone wants some just let me know.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
    • The radial teeth are for hte seconds register, and the other (which is simple and doesn' take away significant torque from the train) for the minutes register.
    • The original 6139A manual is very clear in how to disassemble and how to assemble ...... step-by-step. However I haven't seen the 3169B manual, even in the Japanese version around, which clearly highlights the difference in center-wheel.   6139A Seiko Technical Guide.pdf 6139_A.pdf 6139A.pdf 6139b.pdf 6139B repair guide jp.pdf
